2021 Bronco Redline QuickLift ELITE Gas Hood Strut Kit 21-11040-03
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
Check out the Redline Stainless strut gas shock kit for the Bronco.
As usual message me for forum pricing.
Frank
Ford Bronco 2021 Bronco Redline QuickLift ELITE Gas Hood Strut Kit 21-11040-03 1634927774592
Ford Bronco 2021 Bronco Redline QuickLift ELITE Gas Hood Strut Kit 21-11040-03 1634927826426
2021 Bronco Redline Hood Strut Features:
  • Allows you to delete your 2021 Bronco's prop rod
  • Pair of high-quality hood struts
  • Provides easy opening and improved under-hood clearance
  • Adds 5" of total opening height
  • Easy, no-drill installation
  • Stainless steel struts with powder-coated hardware
Delete your 2021 Bronco's Hood Prop and Get More Room to Work
While your 2021 Bronco may be a capable, advanced, and stylish multi-role SUV, one thing that's holding it back from absolute perfection is the bargain bin stock hood prop. The Redline Tuning QuickLift ELITE Max Lift Hood Struts for 2021 Broncos lets you ditch the stock hood prop for good and make it easier to open your hood while giving you more room to get work done under the hood. The Redline Bronco QuickLift ELITE Max Lift hood struts drop right onto your Bronco and feature a pair of gas-charged strut assemblies that completely support your 2021 Bronco's hood and allow for the complete removal of the stock hood prop. Redline's QuickLIFT ELITE Max Lift struts even open the hood 5" higher than the stock prop rod, which gives you more room to get work done and add all sorts of aftermarket parts to your Bronco without hitting the prop rod and bonking your head -- or worse. Stainless Steel Gas Struts with Progressive Internal Design and Easy, Drop-In Installation
The Bronco Redline QuickLIFT Elite hood struts were specifically designed from ground up to give you smooth operation in a drop-in package. Each of the gas struts included in the Redline QuickLIFT kit feature stainless steel bodies that give them excellent corrosion resistance in practically any climate or application. The struts feature a progressive, slow-release internal design that opens the hood quickly, but brings it to a smooth, easy stop at the top of their travel so that you don't cause excessive wear or break your Bronco Sport's hinges. The struts install using Redline's patent-pending attachment system that does not requiring any drilling or permanent modifications to either your Bronco's hood or body for installation. Each QuickLIFT PLUS kit comes with powder coated hardware and installation instructions so that you can get the struts up and running in practically no time.
Fitment:
  • 2021 Bronco 2-Door
  • 2021 Bronco 4-Door
Will not fit 2021 Bronco Sport: this set of hood struts will not fit 2021 Bronco Sports.
Herbie
Alex
Cleveland OH
2022 Badlands
In one section, in bold it says for Bronco Sport only, then down below it says 2 door and 4 door and that it will not fit the Sport. Can you clarify? Thanks
Stage 3 Motorsports
Stage 3 Motorsports
Joel
Bad copy and paste fail, For Bronco 2dr and 4dr, not bronco sport
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
Installed Redline Tuning’s Hood QuickLIFT Elite at lunch today. Easy install, other than the wire harness clip gave me some trouble.
Ford Bronco 2021 Bronco Redline QuickLift ELITE Gas Hood Strut Kit 21-11040-03 D823B34D-D113-4FDF-8AD5-E9AE61B8A6EF
