I LOVE cut fenders. Front and back, high and tight. Nothing sexier.I cringe EVERY. TIME. I. SEE. CUT. FENDERS.
This is slightly less bad. I guess I should clarify that it matters mostly with the first generation of Broncos.... 1966-1977.Every time?
Absolutely, cringingly ruined. It's bad enough when the cut the rear to match the front, but to cut both of them and leave it looking like THAT? I assume someone had a rust issue and no idea how to fix it (or weld).I LOVE cut fenders. Front and back, high and tight. Nothing sexier.
The only thing worse than leaving it uncut is only cutting the back. When I see an uncut Bronco I have to assume it's a mall crawler at best.This is slightly less bad. I guess I should clarify that it matters mostly with the first generation of Broncos.... 1966-1977.
I'd rather drive a new Chinese Bronco with the special "capabular" front bumper!
There's no shame in wanting a hacked up old Jeep CJ. There's no reason to go ruining a classic beauty to try to hide it!The only thing worse than leaving it uncut is only cutting the back. When I see an uncut Bronco I have to assume it's a mall crawler at best.
Doesn't this have more to do with Chineses restrictions to imported autos? Same reason that Buick and Tesla have plants there?I think Ford is late to the game. The Chinese economy is constricting, and the "easy" manufacturing environment is quickly fading. That said, IF they are able to get this off the ground and keep a legit IP for it they should be able to make a decent show of it.
Ruined??? That's a bit of an overstatement. Here's the fix, like you said, they'll be rusty anyways.This is slightly less bad. I guess I should clarify that it matters mostly with the first generation of Broncos.... 1966-1977.
Gotchaā¦ sorry to hear itās still a lingering issue. Hoped theyād figured that out by now.2.7 in my wildtrak
Ditto!!!Well, at least the cardboard filled tops will make sense over there.
Hey are you talking about my tops!Ditto!!!
More like 40+ years. Back then, No one under 60 years old liked the rear fender shape which is from an early 60ās f100. And to get any decent sized tires on them without a large lift (which no one really had or most couldnāt afford) you had to cut the rear fenders. I agree, to cut an original now is a sin, but I actually like the rear fenders better cut. But thatās about what I was used to seeing when they got fixed up. Iām 64 btw. The good thing is metal is easily replaced.You can pretty much build a new EB from new parts! Now taking an original barn find and cutting it back should be a crime but I'd guess the majority were cut 30 years ago.
