“BRONCO” Grill Badge Light Up
Bronceaux
Johnny
Alabama
2021 Ford Bronco Base Sasquatch, Chevrolet Z71
Got mine on today also, it did take a long time but the biggest pain was hiding all the wires with the Wildtrak grille. I ran mine to Aux 3 and used the prerun cable to the grille. I added the Expel PPF letters at the end as well.
For those wondering, the letters are not as bright as they look in some photos, they are not as bright as the headlights. IMO this is great, it's more subtle, and yes, they do look better in person!
Awesome! You tied into the pre-run violet/gray wire at the grille, and tied that one into aux switch 3 wire violet/green at the firewall, correct? I bought the matte black letters, for my basesquatch. Planning to wire them next weekend. Just making sure I dot my i's, and cross my t's. Great job on the neat wire routing also.
BroncoDymond88
New Jersey
Kia Sorento
That's correct! The "non-powered" circuits listed in the manual (bottom box in the screenshot) are the end points. If you want to power an accessory at those points you have to connect them to one of the Aux wires at the distribution box (the top box in the screenshot). Remember, only the positive (red) wires need to be wired to the Violet/Grey on the grille, the ground (black) wires need to be grounded at any of the existing ground points. The hardest part of the whole thing for me was hiding all of these wires behind the mostly open wildtrak grille. I ended up using really small black cable ties in strategic places to hide them, and then hot glue to keep the cables inside the channels I stuffed them in.
One other thing, I keep Aux 3 switch on AT ALL TIMES. Doing this means the lights are always off except when the vehicle is running with the key is nearbye (not when remote started).
P.S. I did also needed to buy my own wire, the ones that come on the letters are not long enough to do a good job imo.
Good luck!
Bronceaux
Johnny
Alabama
Good luck!
Ford Bronco “BRONCO” Grill Badge Light Up Screenshot 2022-01-09 173557
Thanks a TON. I have plenty of various size zip ties. I also have extra 16 gage wire, and heat shrink connectors ready to roll. Glue gun sounds like a good investment. I will post pics when I am done, to show how the black letters look. It seems most everybody else went with the white letters.
helifino16
Ron
Mount Sinai, NY (Long Island)
Look what arrived in the mail yesterday!
Ford Bronco “BRONCO” Grill Badge Light Up Grill Lights
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Hi, are the sides of the matte black letters white?
The sides of the letter are black, the actual lens under each letter that lights up is clear/white.
Lak34ers
Troy
Seattle
Thank you. Would it be possible to post a pic of them installed and lit up on a vehicle. There are quite a few picks of the white letters installed and lit up. Just curious if they look the same.
Bird Dog Off Road
Jody
Chicago, IL
www.youtube.com
Gonna try to knock this project out this weekend. Can anyone confirm with fuses are ignition only? Is one more ideal than others to use? I have everything I need to do this as far as wiring. Did something similar with my old 4Runner's 'raptor lights'.
Ford Bronco “BRONCO” Grill Badge Light Up 1642179722238
Ford Bronco “BRONCO” Grill Badge Light Up 1642179741271
Ford Bronco “BRONCO” Grill Badge Light Up 1642179757369
BroncoDymond88
New Jersey
Kia Sorento
sorry I can’t help with this. I wired mine to aux 3
boxwood
GA
EV
I am very confused as to why these glow "around" the letters vs just the letters themselves?
Is that designed that way on purpose?
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak
I used 66, Staybar disconnect when doing my switch pod, after quite a bit of trial and error
SwissBronco
Patrick
Switzerland
Jeep JK, JL, Hummer H1,
sadly, yes
I am waiting fot the self glowing letters.
tjnoffy
Jay
Maryland
'21 Bronco OBX Sas, '05 Mustang GT Conv, 2 Harleys
I would use a 12v circuit tester or a multimeter and test the Spare fuses with the truck off and with it on. That way you're not messing with a circuit for something important and possibly hosing it up. Just my 2¢.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Here is how we did it:
Ford Bronco “BRONCO” Grill Badge Light Up Screen Shot 2022-01-14 at 2.22.45 PM
