Razorback
Bill
Dallas
Lincoln MKX
That is absolutely an option, but I would prefer the Ford one so my warranty stays intact.
Ford lists suspension upgrade but who knows what that means or includes...
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
can anyone translate the various availability acronyms?
for example, Q4, what is fourth quarter in ford speak?
for my job, Q4 translates to July through August, while my spouse's, Q4 is October through January
Axe
Poconos
2014 FJ Cruiser, 2018 Camaro
Rhymes with schmunderfelmed.
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
DUSTYcazOREGON
Craig
Your SPOUSE is right.....they are always right!?
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
I don’t know for certain, but typically, if a company’s Fiscal Year (for accounting purposes) is the same as the Calendar Year, the date acronym for the 4th quarter will just be listed as “Q4”. If the Fiscal Year is different than the Calendar Year, it will typically say say something like “FY Q4”. Most publications targeted at consumers (versus financial reports targeted at analysts and investors) will adhere to a Calendar Year convention. So I suspect that Q4 here simply refers to the Calendar Year and means October through December.
DUSTYcazOREGON
Craig
Any clue what the hold up is on the Performance Winch. M-1821-B The new Ford mount maybe?
Lcubed
l
UsA
neither of our jobs add FY to the Q4 on documents, they both assume you know it's relative to the fiscal year
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
Soft top
Tune
Swing gate
Pods to be retrofitted as Fogs
My dealers gonna love me, although I'm still going aftermarket for mostly everything else.
Definitely iffy on catback's though, more because I want to avoid Drone, while HFC's give me the power and tone I like
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
Because maybe you need the air Design moldings for that time you ask your mom to move your truck.
Razorbak86
Northwest Arkansas
Understood. That’s why i said “typically” and noted differences for specific audiences.
Anyway, I just looked up Ford’s fiscal calendar, and it is January to December, so in this case, FY and CY are the same, and Q4 means Oct-Dec.
BR0NCO
Randy
Mass
Jeep Audi
Not "rot" so much as disintegrate in the 110degree blazing sun.
I thought about 5-tire rotations since we get the 5 matching rims, and I like the idea of showing off my 5th matching rim. But that commits me to buying 5 tires instead of 4 the next time I have to replace all of them.
Anyone know if the extra life on my tires doing 5-tire rotations will offset the extra expense of replacing them 5 at a time?
If you rotate in the spare you get 20% more life out of the set. Rotating that spare makes a rotation simple easy because you only need one good jack and only one corner is off the ground at a time. You can do the whole swap in 10 minutes. If you need to use the spare it will already be worn close enough to match the diameter of the others. If you don’t rotate in the spare because you think you are saving from having to buy a 5th, you will have to get the same size and type of tire next time. Can’t decide to go bigger unless you buy a 5th anyway.
