DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
Do we know what the center hub size(wheel bore hole size) is? Not a guess, not assuming it is the same as a Ranger...but an actual fact? Someone said the Ranger is 93.1mm But we need the Bronco size confirmed. Thanks
DUSTYcazOREGON
Craig
How does the back space (I believe, as an example the Black Diamond has been said to be 4.75") come into play when ordering an aftermarket wheel? Would not the size of the wheel, the offset, bolt pattern and bore hole size be what is important. Or does backspacing come into consideration also? Would not back spacing be effected by a change in/when changing the offset? Thanks
hellahella
Adrian
Nevada
Ford Bronco
I hope we can get more info regarding the weight of these. Planning on throwing some Advan RGD2's or some Fifteen52 if the optional BL wheels are heavier
adrianmaz
Adrian
Seattle, WA
Lancer Evolution X
So is there any confirmation on whether the Sasquatch wheels are forged or cast? I’ve read through the thread and have seen just a lot of speculation.
Thanks Zack, I had seen a post that Dicastel was known as a cast manufacture. Plus the trusty B&P does not mention forged:
That’s odd, Ford’s own spec sheet says they are forged. Since aluminum can be either cast or forged, and B&P doesn’t specify which, it’s technically not contradicting itself, but instead underspecified on B&P.
But TBH, it does say PRELIMINARY Spec sheets, and things have been pretty dynamic over the past 6 months with the Bronco development team...
https://media.ford.com/content/dam/fordmedia/North America/US/product/2021/bronco/pdf/2021-Bronco-2dr-4dr-Prelim-Tech-Specs.pdf
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Is there any info on the optional wheels for the black diamond? I don't see those pictured or listed. I'd consider opting for them if they were wider than the steelies.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I haven't seen specs on them anywhere now that you mention it.
I suspect they are also 7.5" wide... as they are paired with the exact same 265 tire that comes with the steelies.
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ Wheel and Tire
Also, this is a really weird description:
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ Screen Shot 2021-02-09 at 15.19.05
Studawg
SC
02 Excursion, 96 Land Cruiser, 18 Land Cruiser
You are saying the Sasquatch wheels are flow-forged? Isn't that the same thing as "spun-cast"?
RiseAbove
Tom
Fort Mill SC
Dodge Challenger RT
Correct. Sas has the silver ring and Wildtrak has a black ring.
I’m assuming that the black ring will be an accessory we can buy? I’m not the biggest fan of the silver and black.
Toccoa
Isuzu Rodeo Sport
It may not be listed as an accessory, but it will be available in the parts department. I plan on replacing mine with black as well (silver looks tacky). Short term, I’ll just plastidip the rings until the parts are available.
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
It seems that the majority of Method Trail Series and Teraflex Nomads are zero offset/4.75" backspace. Will those fit properly on a Badlands with 37" tires?
Or will it cause rubbing/interference issues?
RiverRat001
Jesse
Buffalo, NY
14 Fusion, 18 Grand Caravan, 78 F250, 81 CB750F
Question for the tire experts here... can I run the 285/70r17 (33”) KO2’s on the BD steelies? Not sure if the drop from the 8”-wide BL wheels to 7.5” is a dealbreaker.
ya know, in case someone wants to run their badlands incognito as a BD... asking for a friend 😉
Laminar
Iowa
Cougar
RiverRat001
Jesse
Buffalo, NY
The Dmv
D
Louisiana
2021 Bronco 2d Base
Stig got photos all the wheel sizes and offset numbers for y'all that are on the rims! Hope this helps with tire upgrade plans! Enjoy.
Table added by @North7
Nicely done, thanks!
