Seacat
Robert
2022 Bronco Wildtrak, VW Touareg TDI R-Line
Hello all! With the success of the IAG EZ Steps, we are working on a full length board option for the factory rock rails. Pre-order won’t go live until we have completed the packaging design. Production will begin in late April. Deliveries would begin in early May. As always they ship in the order received! Please provide feedback. Anticipated pricing is $899 for 4dr and $849 for 2dr.
The color and finish of the 2dr step is consist with our current offerings and matches the OEM rock rail. That’s what we intend on using. The 4dr step is something we were experimenting with and didn’t turn out in a way we are happy with.
I know these are preproduction models pictured. Will there be any center supports mounted between the attachment bar and the outer running board pipe on the 4 door model to prevent it from sagging from use?
ColoradoGuy
We are going to do these a bit differently this time around. We should have some additional information to share on Monday that we will post here.
Looking forward to your update. In the meantime, do you have any other pics you can share of the 4DR version? Someone mentioned that you had these at super celebration east?
Oceannomad
Jonathan
SE Virginia
2021 Audi Q7
Monday as in today Monday?
btw I suck with waiting
Bronco1988
Vinnie
Sasquatch Bronco
Looking forward to the update!
IAG Performance
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
Good morning! Based on some of the feedback we have received we have decided not to do a traditional pre-order on the full-length steps as we have done in the past. We are going to have a link to sign up for automatic notifications when they are in stock and available to order.
Biggwrm
Orran
Gilroy CA
2018 Raptor
Darn, this group is quite used to preordering… im fine with it 😂
Seacat
Robert
I know these are preproduction models pictured. Will there be any center supports mounted between the attachment bar and the outer running board pipe on the 4 door model to prevent it from sagging from use? I'm 6' 2" 240lbs, stepping on this 4 or 5 times a day will probably cause it to sag. Trying to save you the headache of complaints after the sale/purchase.
IAG Performance
IAG Performance
JJ
Westminster, MD
No there won’t be…but what you may not see is there is an inner tube as well. Additionally there are two center supports that hang off the rail. In our testing (putting 2 people on the step at the same time) it doesn’t flex or sag at all.
Oceannomad
Jonathan
SE Virginia
2021 Audi Q7
Well let us know when this puppy is out. Poor wifey will struggle to get in until then
Jpursuit
J
Houston
2008 f250 king ranch 4wd, 2021 Bronco
These attach to the OEM rock rails.
I'm interested to add these on to my Badlands rock rails but have a question for you guys. As you likely know, the factory rock rails extend forward slightly beyond the body. Some of us, including me, have cut the front of the rails back between 1 1/2" and 2" to fit aftermarket mudflaps. Will your full length EZ-STEP still fit on rails that were cut back up to 2" at the forward end?
SVTLightning
Christian
Canada
Titan
Looks like it will be close but tentative yes for fitting even with cut back sliders.
Ford Bronco ⚠️⚠️Teaser❗️❗️❗️Full Length EZ Step Board Add on for factory rock rails! 2dr and 4dr. 7990A5BE-7371-4D16-B484-EDBB15996AEA
Bronco Bax
New Jersey
Price gouging? You can’t be serious. The cost of entry for the equipment making these steps is over 1.5M. They are made of quality domestically sourced Materials and all hand tig welded. This isn’t a cheap mig welded product. Additionally material prices have increased by nearly 300% in the last year. (Another 10% last Friday). There is nearly $350 in materials in a pair of these steps 😂 ….simply not possible to manufacture and sell in the US for $400-600. Take a stand if you will, but it isn’t going to mean we can lose money to offer these to the community. If you are happy with your Go-rhino than we likely aren’t the company for you.
haha sooooo are you saying there is room to sell to b6g members for $700-$800?
IAG Performance
IAG Performance
JJ
Westminster, MD
It's going to be close but I'm hesitant to guarantee that it will. With the step centered on the rail I measure 1.5" from the step mounting bracket to lower edge of the rock rail.
Ford Bronco ⚠️⚠️Teaser❗️❗️❗️Full Length EZ Step Board Add on for factory rock rails! 2dr and 4dr. Ste
