WARNING
*Update 3* IAG Performance has sent an email out to everyone who purchased a EZ-Lift Soft Top Assist with your options for rectifying the problem. If you didn’t get an email reach out to IAG Performance by email at [email protected] or by phone at 410-840-3555.
*Update 2* Messaged with Adam Kennedy from IAG this morning after taking measurements from the soft top frame and IAG struts to the pillar in all 3 top positions. The measurements showed the soft top frame is centered side to side on the Bronco and that the IAG struts are evenly spaced from the pillars until the top is fully in the down position. That’s when the IAG strut rubs the pillar on the passenger side but is still spaced out on the driver side.
IAG is going to send replacements parts and is refunding the cost of the struts. They offered to send touch up paint and PPF but I’ll be getting the whole vehicle PPFed shortly once my advfiberglass fenders get here so I told them they didn’t need to do that. Also, I’ll be getting touch up today because I don’t want to leave metal exposed that long.
*Update* Adam Kennedy from IAG has reached out to help resolve this and we will be working through it to try and figure out the cause and a resolution for the damage tomorrow. I will update the post with what we find out and decide.
*Original Post* I got my Bronco last Thursday (3/10) and my IAG Struts arrived on Saturday (3/12) so I of course eagerly put them on my Bronco the same day. They went on great with easy to follow instructions and I was loving using them. That is until tonight when I started hearing a rattling noise on the passenger side rear of my Bronco. I went back to try and find the source of the noise to find that the IAG struts had been rubbing against the D pillar (arms over the rear of the bronco). In fact they had rubbed clean through the paint on both my Bronco and the strut.
My initial thought was surely the strut had bent or something was loose and causing it to be out of alignment but I thoroughly inspected it and there is nothing bent, angled wrong, moving irregularly, or loose. Also, the driver side is not rubbing at all and has a healthy gap between it and the D pillar. I don’t know what caused this whether the bracket it mounts to is angled slightly different or what but there is nothing from the top itself even contacting the strut other than at the attachment points.
I really hope @IAG Performance makes this right by paying to have the paint fixed on my Bronco. Unfortunately, their customer service is closed all weekend so I won’t be able to reach them until Monday morning most likely. Also, their website says “Our liability shall under no circumstances exceed the actual amount paid by you for the product, nor shall we under any circumstances be liable for any consequential, incidental, special or punitive damages or losses, whether direct or indirect.” So unless they stand up and do the right thing I will be out of luck.
I made this post right away so others wouldn’t fall victim to my same situation. If you have these installed already, check to see if they are close to your paint when the top is in the down position.
I will update y’all when I get an answer from IAG on how they are going to handle this.
