I stand corrected. Shiny little hubcaps are even less manly on a truck than white tire lettering.
Never had any BFG last more than 2 years, no thanks. Also no better than any other AT in mud, yet look like they should be.Two styles of KO2s have been built, the older style (early KO2) are 35.6 and the newer ones 36.5.
The older ones wear like iron which is why I’ve had mine so long, they look tiny on a stock height H2.
Right now believe it's a separate accessory!Is the fastback top an separate accessory or is that the regular soft top?
MAP will be making the Warthog and these are the test tiresGreat pics, thank you!
But why is there a pic of a 37 x 12.5 BFG In the mix here?? Is the factory gonna install them on something soon?
Mine are 5 years old now, and appear to still have 50% tread. They are fantastic in sand and snow as well as all the trailing I do. They are awful in mud - absolutely horrendous.Never had any BFG last more than 2 years, no thanks. Also no better than any other AT in mud, yet look like they should be.
looks like the white Bronco is an OBXOx White O.B. two door fastback soft top, needs an Ox White hard fiberglass rear tire cover for a factory finished street look... (hint, hint)....
Well I did like them. Till I read this. ?I don’t like the fastbacks. Makes it look like a dump truck ran into the back of the Bronco on the interstate and smooshed it.![]()
Yes, Yes and even more yeses to come a completely new breed underneathThe interesting thing is those wheels look like the badlands optional ones. I wonder if that means he Warthog rear axle and front control arms are wider and therefor require more offset than Squatch.
Warthog is a 2023 model start running test units through the plant starting June 2022As someone that has the FE edition as an official order now, this frustrates me with all the talk of the Warthog, especially when just a 37" tire is hinted at "oh this for the Warthog" If Ford is going to release the Warthog anytime soon they should make an announcement. I believe they are going to make the announcement when Jeep makes the Wrangler 392 ready for ordering. I guess in the end I Ford will make the announcement before I pick up my FE Bronco and I can always cancel then.
I hope so. If I get this thing instead of a standard hardtop on my 2 door after getting pushed to my22 I’m going to be bummed out.Right now believe it's a separate accessory!
HopefullyHas Ford ran out of the MIC hard top
