πŸ“·4600 ripping in the desert+added pics!
Apples
Nick
2022 Jeep JLUR, 2004 Lexus GX470
Question for you if you don't mind...
First ,I agree. I think this thing has 3 inches over sas height. My question is do the portal hubs allow better CV angles than the standard? I know this is running RCV CV half shafts, but what do you feel is allowing for CV angles that aren't too aggressive (that is presuming they aren't too aggressive)? 3 inches+ is generally on the edge for IFS, if you want boots to last and not bind up.
Yep, the portal axle setup allows the CVs be be practically stock articulation while still allowing for ~3" of lift.
It's too bad that those spindles will probably be stupid expensive. Like small mortgage expensive.
BAUS67
redneck
Central PA
Don't mind at all. It is just one old man's opinion. These pics shows it a lot better. and I will try.
I don't know the exact orientation but The orange boot (top pic) would be the top gear (bottom pic) Then the wheel (top pic) is on the bottom gear (bottom pic) Adding whatever that distance is between the two gears 3-4 inches ??? would be the lift. Much better on cv angles than just pushing the cv to it's limit.
Ford Bronco πŸ“·4600 ripping in the desert+added pics! 1615610722723
Ford Bronco πŸ“·4600 ripping in the desert+added pics! 1615610870339
BAUS67
redneck
Central PA
74weld posts they are working on "cost effective" alternative, after r&d with the 4600.
395N
Orange County CA
22 Jeep Rubicon XR
I don't know the exact orientation but The orange boot (top pic) would be the top gear (bottom pic) Then the wheel is on the bottom gear (bottom pic) Adding whatever that distance is between the two gears 3-4 inches ??? would be the lift. Much better on cv angles than just pushing the cv to it's limit.
Is the spindle part of the portal hub? In other words, is it all one piece?
395N
Orange County CA
22 Jeep Rubicon XR
Thank you!
I always wondered.
BAUS67
redneck
Central PA
Yes spindle/ hub assembly would come out of the bottom gear somehow. Sorry guys I'm not an engineer have a hard time with terms.
Apples
Nick
This would be a normal setup. You'll notice the CV (drive shaft) lines up with the center of the hub, which centers the tire. The portal axle adds a compound gear to the mix so that the hub and wheel are lower than the CV
BAUS67
redneck
Central PA
Here is the post
395N
Orange County CA
22 Jeep Rubicon XR
Got it.
I understand now.
I am getting these when they become available.
Thank you for the explanation(s).
395N
Orange County CA
22 Jeep Rubicon XR
I dig it.
All over this when it comes to market.
Thank you.
BAUS67
redneck
Central PA
Got it.
I understand now.
Portals have been around along time nothing new other than the tech update the idea.
The Bronc will make it popular. not just for your Humvee or Mercedes. ;)
I drew the gears in there for you.
Ford Bronco πŸ“·4600 ripping in the desert+added pics! 1615612265847
BAUS67
redneck
Central PA
Guys I just noticed the bracket behind the the skid πŸ€” something for winch maybe ???? but looks aluminum, but is thick.
Ford Bronco πŸ“·4600 ripping in the desert+added pics! 1615612505595
395N
Orange County CA
22 Jeep Rubicon XR
I knew the Humvee has them, wasn't aware of Mercedes.
BAUS67
redneck
Central PA
