I bet you're right. And I bet it's mounted upside down.Guys I just noticed the bracket behind the the skid something for winch maybe ???? but looks aluminum, but is thick.
The post from 74Weld, that I posted earlier, says 4 gear. FYIPortals for the bronco will need 3 gears FYI. Otherwise drive becomes reverse
Right side extended you say? Well that pic is taken head on on the rocks. Im not seeing it, but its level if you look at my red lines and if right side extended? Yellow lines wouldve been where it should be?
With that new pic, it looks like the winch is maybe in front of the front diff. Putting a pulley or a guide to get the cable where it is.
Looks huge with just 35's. That flat UCA gives me the fizz.New pic!
It takes away the bloated after Thanksgiving meal look for sure.It's that flare to tire gap.
You can bet It's still going to be pricy and you may need to re-gear the rear to match as most portals that I know of are gear reduction units. They also require more frequent service for the juice in the portal boxes.74weld posts they are working on "cost effective" alternative, after r&d with the 4600.
You betcha' they are pricey. Just ones for SXS are 4K.You can bet It's still going to be pricy and you may need to re-gear the rear to match as most portals that I know of are gear reduction units. They also require more frequent service for the juice in the portal boxes.
Well we always said Just Empty Every Pocket (Jeep) I guess we can say For Obvious Reasons in Debt (FORD)You betcha' they are pricey. Just ones for SXS are 4K.
Just the portals. Make them beefier, >>>>>>>>>Throw in axles, coil overs, knuckles. That is just the front.
