PSUTE
Western Maryland
Sierra
Does it have that heavy hood insulation? Inquiring minds want to know...
Opossum
Zeke
Dallas
I'm a graphic designer ..that's photoshopped
You can see the area they tried to patch together in the circle..
Or it is a crack in the windshield. If they were that sloppy for the one pic, I'd expect more for the other two.
Ford Bronco ?4-door Bronco Outer Banks test towing a big empty trailer 20210108_231603
*Edit* It has been brought to my attention that it may in fact be a dead pigeon with a string tied to its leg.
Motown, Motor City, DeTwah, Detroit
XJ Cherokee, 1971 Z28 R/S
Found this on Facebook. Just wanted to post the picture so you can see what it looks like when the bronco four-door is towing a large trailer.
**Not my photo
Thanks for sharing
**Not my photo
Thanks for sharing
That’s a chip in the windshield
codydb19
Cody
Silverado
Oh it is..did you see it personally?
Ford Bronco ?4-door Bronco Outer Banks test towing a big empty trailer IMG_2490
Oh. I thought you were kidding about that rock chip being proof of a photoshop gone wrong....
What would be the motivation for someone to spend hours making this photoshop?
Especially since it would be one of the better one’s I’ve ever seen, doubly so considering we haven’t seen this Bronco before.
PromoFLB
Frank
VW GTI, Lexus GS, and Lexus CT
Definitely an OBX based on fenders and wheels.
Toccoa
Isuzu Rodeo Sport
Ford Bronco ?4-door Bronco Outer Banks test towing a big empty trailer 1610166961966
Looks like a trailer full of 2021 available accessories.
Kos
Omaha, NE
2022 Ford Bronco Badlands
My gut has always been that tow rating was low versus actual capabilities. Seems like too much engine (especially the V6) for 3500 lbs. Also, all engines and power trains have the same rating?
Norm A.
Norman
If it's photo shopped they did a pretty good job, even the safety chains are hooked up in the right spot ?
PartyMarty
Marty
2016 Jeep Wrangler Black Bear, 2009 VW Rabbit
Thanks for the pictures. This looks very promising, as the rear suspension seems to be barely sagging if at all with this large (but empty) trailer. Our 4 door wrangler sinks more in the rear with just a jet ski in tow, and sinks almost down to the bottom with a 3500 lb enclosed work trailer (I only tow that at low speeds around refineries), and that wrangler is rated the same as the bronco at 3500 lbs. I don’t want to speak too soon, but this helps solidify my suspicion that a 4 door bronco can be capable of safely towing more than 3500 lbs if necessary.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
It must be right on the nose. All sorts of modifications to that trailer, looks like they were done to reach a certain weight.
csj
Craig
17 Tacoma OR
Doesn't look photoshopped to me. Anyone have any idea what that trailer weighs? Looks like a medium size steel trailer.
