- Terry
- Aug 31, 2023
- 102
- 509
- 334
- New Orleans, LA
- Bronco, RAM TRX, Gladiator, Wrangler JL,
- Base
When we were developing the OCULUS BI-LED Projector Headlight, we took aim at the OEM LED headlight market. We wanted to be the GOLD standard for upgraded, full replacement housings for the 6th Ten Bronco. To accomplish this, we needed a stronger beam pattern, cleaner cut-off with little to no glare and a full fill to illuminate the roadway ahead and do so in a full housing and other elements in the headlight package.
https://www.oraclelights.com/collec...led-projector-headlights-for-2021-ford-bronco
The BRONculus comes in multiple options all produce a brilliant 5200 Lumens. You can select to upgrade to the Oculus Switchback adding an amber to the DRL halo the signaling a turn. To completely customize your vehicle’s look, the Oculus ColorSHIFT BI-LED Headlight is available with 3 zones that can be controlled together with the included BC-2 controller. The zones can be separately controlled by adding more BC-2 controllers.
The new modular design allows separate components (turn signal, marker lights, and mounting tabs) to be installed independently. The modular design also allows for these individual components to be replaced or upgraded down the road when future options are available.
Check out what our customers are saying:
“Excellent quality, easy install and great lighting upgrade. Great halo effects and very big upgrade to night driving with high and low beams. The auto highbeam works better than factory. Very happy with these lights. Easy to use controller and also a smartphone app that works as well. I highly recommend these for a lighting upgrade.” Lisa
“Amazing Improvement!! Installed on my ‘21 Big Bend to replace the standard lights. Easy to install and an amazing improvement overall” Joanna
