🛠 11/1/21 Build Week Group
Monstertorch
Oregon
GMC, Chevy, Mazda, Ducati
Home safe and sound! Modification start tomorrow!
Palerider
Bruce
Naples, FL
Gladiator
Yes, ford covered it under warranty. After I figured out what I did wrong, it's really simple to take out the back window. I emailed the dealer and they told me to bring it in. They took pics of the old one and ordered it and that was back in late November. I asked them after they did pics if I can do a temp fix and they said yes. So I super glued the damn thing back up and it was good as new. Just a couple days ago my new rear window came in and I swapped it out and returned the broken one for the warranty claim. If you were to buy the window out of pocket, it was around $250 or so. Below is a video on how to properly take the soft top windows out. At the time all the videos online didn't really give you a close up of how they popped the rear window out on the corners. Saw this video with a lookalike randy savage and saw what to do. Hope this helps, let me know if you have any questions!
thanks so much. will turn in for a warranty claim. my son put tie wraps around it. son's fiance had locked the keys in the bronco and she was trying to remove the rear side window and didn't understand how. she broke the plastic clips from the rear window trying to get in.
First2GoLast2No
Edward
Vacaville, California
Added some Rough Country ditch lights, easy install with the aux switches for sure👍🏻
Installing these rough country lights did you have to cut the included wire harness? Where did you cut it? Before or after the relay on the harness?
Richw23
Rich
Massachusetts
Grand cherokee trailhawk
I used the connectors on each light and basically only used the red & black wires from the wire harness. Grounded black to body and connected red to the yellow and green wire for the aux switch. U dont need the 3rd wire if u have the aux switches and u dont need the fuse box on that same wire because u dont need the switch that comes with it. Hit me up if u need more info, i can send u finished pics of under the hood.
Richw23
Rich
Massachusetts
