Plantation Fordwhere did you order from see you are in Plantation like me
Same Here. Maybe ours will arrive on the same trainPlantation Ford
We're not too far off from each other. Same blend date and about 600 apart in line.The power of positive thinking?
You're at least 1600 away from me and I'm like 2000 away from the last guy that verified his Mods Popped. (Anyone between is probably still waiting like the rest of us.) I like the way you think, though.
Yep, tomorrow will be a BIG day for us. Fingers ready to refresh 300-400 times.We're not too far off from each other. Same blend date and about 600 apart in line.
Mine hasn’t changed from/since 12/2 but if 12/6,7 being your blend, check your mods and let us knowDoes the date at the bottom of the window sticker have significant meaning or just change each day that you open the link to your window sticker? I opened it on 11/30 when I found it for the first time and the date at the bottom said 11/30/21. I opened the link again today to see the date at the bottom say 12/7/21 (todays date).
Looks like it's just the date that it gets pulled. I had the same thing on my original one that I downloaded says 11/30/21. I just went in and looked at it online and it says todays date. I guess I wouldn't know for sure until i check again tomorrow.Does the date at the bottom of the window sticker have significant meaning or just change each day that you open the link to your window sticker? I opened it on 11/30 when I found it for the first time and the date at the bottom said 11/30/21. I opened the link again today to see the date at the bottom say 12/7/21 (todays date).
Hi all just registered as a user here and have a blend date of 12/11 for my BL 2.7. Found this thread very interesting and added my data to your spread sheet. Hope that’s okBringing to the front again
You’re a 12/6 build week, you’ve come to the right place.Hi all just registered as a user here and have a blend date of 12/11 for my BL 2.7. Found this thread very interesting and added my data to your spread sheet. Hope that’s ok
I see you now at 2078, so good question. Mine hasn’t changed, but I just keep refreshing my WS and haven’t tried going back to the pizza trackerDoes the date at the bottom of the window sticker have significant meaning or just change each day that you open the link to your window sticker? I opened it on 11/30 when I found it for the first time and the date at the bottom said 11/30/21. I opened the link again today to see the date at the bottom say 12/7/21 (todays date).
Not working for me. The 11/29s and 12/13 & 20s wearing it out!Is the bronco6g tracker working for anyone?
are we trusting the two loan mods popped on the sheet are accurate? I think they might be a little prematureIf the sheet is correct, only 1,696 builds to go - for me! A shift, shift and a half? So maybe tomorrow!
My bubble was burst right after I hit enter and read Hellifino’s post. Makes complete sense…rouge Ysare we trusting the two loan mods popped on the sheet are accurate? I think they might be a little premature
LowerDixie77 did confirm his modules earlier. So the first 4 are probably correct. The other two randoms below Im sure are mistakes or they misunderstood how it works.are we trusting the two loan mods popped on the sheet are accurate? I think they might be a little premature
