- Banned
- #106
The Ford Trucks vin decoder says my Bronco is a Base even though my confirmation email from ford shows as outer banks (with the vin). The link here doesnt pull up anything with my vin and order number.
Yeah, there is usually a drop down menu that shows a few trims lumped in there together. Not sure you're using the see VIN decoder, but it doesn't specify particulars, at least not for several trims. I believe Wildtrack and First Edition are separate in a similar drop down menu.The Ford Trucks vin decoder says my Bronco is a Base even though my confirmation email from ford shows as outer banks (with the vin). The link here doesnt pull up anything with my vin and order number.
NVM, I was using the order number and not the Order pin. No window sticker but the tool on this site is 100% correct.Yeah, there is usually a drop down menu that shows a few trims lumped in there together. Not sure you're using the see VJN decoder, but it doesn't specify particular, at least not for several trims. I believe Wildtrack and First Edition are separate in similar drop down menu.
I'll see if I can find it.
Same problem here, I could swear it worked before.Was there an update to this tracker last night?
For a while I’d enter my order and VIN and it would say can’t locate VIN, but would still show general information about my build and order. Today it pulled up the button for the window sticker (doesn’t work when I click it yet) but I hadn’t seen the button before
I’ve heard they don’t populate until 7 days before your build date, unless mine changed, Ford says week of 6/28, so I’ll be waiting a bit!Same problem here, I could swear it worked before.
My window sticker just started showing I think on Friday and my build date I think sits on the 17th. So little longer than a week.I’ve heard they don’t populate until 7 days before your build date, unless mine changed, Ford says week of 6/28, so I’ll be waiting a bit!
Is the VIN and Order number collected by this web application or saved in any way?Enjoy our Bronco order tracker tool which pulls up build specs, photos, production status, ship/transit info, window sticker, etc. on your Bronco!
Bronco Order Tracker Tool [Enter VIN & Order #]
Rest assured, no data is recorded or saved in any way. Nor is any data passed on or shared in any way. This tool is here solely for the direct benefit of Bronco6G users.Is the VIN and Order number collected by this web application or saved in any way?
Or are the details only passed to Ford and temporarily presented to the user?
Thank you very much!Rest assured, no data is recorded or saved in any way. Nor is any data passed on or shared in any way. This tool is here solely for the direct benefit of Bronco6G users.
Build timing doesn't go off of order date...more closely tied to your reservation date.I'm looking forward to getting my VIN but don't know when that will happen. I have a confirmed order date of 3/17/2021 for the Badlands with Sasquatch package.
Not even reservation date is as important as we all thought. Pretty much goes by constraints. Less constraints you have the better the chance you will get a vinBuild timing doesn't go off of order date...more closely tied to your reservation date.
Note: none of your inputted data is recorded or saved in any way. Nor is any data passed on or shared in any way.
Window sticker will only show up 7 days before actual build date.everything loads up nicely but when I hit load window sticker this is what I get!! does this mean i got more delay surprises coming?
