DubC
DubC
Houston, TX
instagram.com
2021 Bronco, 2016 F150, 2022 Highlander
Nice job on the compressor. Quick question about your Fog install. I have the exact same kit, just waiting for my ride. To get the wiring harness from the passenger light over to driver side, I assume you ran it behind the skid plate, between skid and bumper? Did you fish it with a wire hangar or something of the sort or did you pull off the plate? Thanks.
Yup, between skid and bumper. I was able to just push it through! šŸ™ŒšŸ¼ I did have to fish it up from the driverā€™s side into the engine bay though.
Herbie
Alex
Cleveland OH
2022 Badlands
Perfect, thank you very much.
GeoWar64
Geoff
Sunset TX 76270
That black is beautiful but damn I cant imagine it in Texas summer...whew.
Agree on both counts. Texas summers are intense, so I replaced by black Ram pickup with white Bronco. Canā€™t get away from the black soft top, but a plan to install ceramic window tint - itā€™s supposed to reject up to 80% of the sun's heat-producing infrared rays.
DubC
DubC
Houston, TX
instagram.com
May I ask the name of that arm? is it compatible with RAM ball mounts?
Itā€™s a telescoping arm by TackForm. Not compatible because if I remember correctly, RAM ball mounts are 1ā€ and TackForm accepts 20mm ball mounts.
nineagel
Oleg
WA
Colorado ZR2, Bronco BL
Got it. So charger itself is a 20mm. I really like that setup. If you can share the link for that product it would be awesome. Looks like TacForm has so many options...
DubC
DubC
Houston, TX
instagram.com
Charger is actually 17mm. Need an adapter for it. Hereā€™s a link back to post #140 that has links to everythingā€¦
https://www.bronco6g.com/forum/thre...k-badlands-sasquatch-build.25329/post-1057938
I also use a 67D arm. Theyā€™re 20mm as well and a lot nicer looking. I have this one in mediumā€¦
https://www.67d.com/products/carbon-fiber-arms-matte
21BRONCO
William
Los Angeles
@DubC question about your painted grill. Did you paint your original badlands grill that came with the car? If so, how much did it cost you for it at the shop? Planning to do the same and was wondering.
DubC
DubC
Houston, TX
instagram.com
Yes had the original Badlands grill painted. Cost about $400.
AIGAD
Tom
UT
2021 Badlands Sas
Do you rest your phone on the dash with the Tackform arm or let it hang over like pictured? I have the same setup, but with a 67D arm and I let it hang over the dash, but it vibrates up and down when driving. It's pretty annoying. I may need to move the base of the arm closer to the center of the rail where its more secure.
DubC
DubC
Houston, TX
instagram.com
I let it hang over as pictured. I also have a 67D arm and both the TackForm and 67D arm donā€™t vibrate at all for me.
Broncojy
Johnny
Dodge Neon
Do you have that same rail from archetype designs? The one he has is really long and maybe provides more stabilization. I have a much small rail probably 8 inches and noticed when I put pressure on the arm the rail leans downward. Idk just a theory.
AIGAD
Tom
UT
2021 Badlands Sas
I have the same long rail from Archetype. It's flexing a little from the weight of the phone. I'm going to move the mount more towards center of the rail. I also need the double sided tape on the feet of the rail. Hopefully, that fixes it.
Fordmanbob
Bob
KS
2018 F150 4x4 supercrew, 2006 F350 4x4 superc.
Damn fine rig!
Fordmanbob
Bob
KS
Only two weeks shipping? Man, I'm getting nervous. My Bronco left on the 4th and its in a black hole in Illinois according to the report from the dealer.
Probably in a railyard
