This was answered in one of the KOH vids. The lady tried it in reverse. That was a negative. Did not work in reverse.Wonder if it will work in reverse!!!
Damn! LOLThis was answered in one of the KOH vids. The lady tried it in reverse. That was a negative. Did not work in reverse.
It better! LOL. That's when we're using it...as soon as we go UHOH!Wonder if it will work in reverse!!!
HOW CAN THAT BE???This was answered in one of the KOH vids. The lady tried it in reverse. That was a negative. Did not work in reverse.
It's listed as available on the base without sasqautch per the chart issued by Ford. I haven't seen anything stating otherwise.Is this thread stating that all automatic Broncos get trail turn assist? Thats including Base with no Sasq? Because it would seem that feature starts in the BBend
Literally just read that.. Haven't heard or seen it anywhere else including when you're on B&P and do a 360 on the interior, that button begins to only show up starting on the Big Bend but I'd trust their lineup sheet over the specs on the B&P. Thanks for the responseIt's listed as available on the base without sasqautch per the chart issued by Ford. I haven't seen anything stating otherwise.
Order guide seems to imply that all automatics get it, irrespective of the Trim level.Literally just read that.. Haven't heard or seen it anywhere else including when you're on B&P and do a 360 on the interior, that button begins to only show up starting on the Big Bend but I'd trust their lineup sheet over the specs on the B&P. Thanks for the response
Man I knew you'd have the answer Thank u kindlyOrder guide seems to imply that all automatics get it, irrespective of the Trim level.
Wonder what the difference is between the Manual Hill Descent Control and the Automatic Trail Control?Order guide seems to imply that all automatics get it, irrespective of the Trim level.
Here, even more clear here:Man I knew you'd have the answer Thank u kindly
Here's how Ford has described each... not sure that this actually clears anything up.Wonder what the difference is between the Manual Hill Descent Control and the Automatic Trail Control?
