Sold: California $100 - OEM rear steel bumper from Badlands - SF Bay Area
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
OEM Badlands steel bumper is available for you! This is the OEM bumper that comes with the Black Diamond, Badlands and First Edition. It's in good shape. No dents, no major scratches or blemishes. It comes with the OEM tow hooks from the Badlands. Does NOT have the four bolts used to attach to the frame, but I assume those are identical to what attaches the plastic bumper. (Note the word "assume".)
It does NOT have the parking sensor harness. But it has the holes and mounts for the parking sensors. (I reused the parking sensor harness in the replacement bumper.)
From what I understand, the parking sensors on the OEM plastic bumper are shaped differently so a bit of tweaking may be required to get them to seat properly. But I don't know if that's true. I read it here on B6G! The parking sensors are not sensitive to how they are mounted. I had to re-mount them in the new bumper and noticed it's a very different fit. They work just fine.
$100 and it's yours. Come pickup in Berkeley, CA.
Ford Bronco $100 - OEM rear steel bumper from Badlands - SF Bay Area IMG_3240
Ford Bronco $100 - OEM rear steel bumper from Badlands - SF Bay Area IMG_3232
Ford Bronco $100 - OEM rear steel bumper from Badlands - SF Bay Area IMG_3233
Ford Bronco $100 - OEM rear steel bumper from Badlands - SF Bay Area IMG_3235
Ford Bronco $100 - OEM rear steel bumper from Badlands - SF Bay Area IMG_3237
Ford Bronco $100 - OEM rear steel bumper from Badlands - SF Bay Area IMG_3238
Ford Bronco $100 - OEM rear steel bumper from Badlands - SF Bay Area IMG_3239
