Jdc
Jon
Massachusetts
Bronco Badlands
Because someone at Ford said 10R80 by mistake instead of 10R60....the internet did it's thing from there.
Because somebody on the internets said it's going to explode as soon as it leaves the lot
Zero_chance
JD
AZ
www.southvalleymustang.com
17 Mustang
Straight from OEM workshop manual.
The 10R60 automatic transmission is a 10-speed electronically controlled transmission with a main control valve body unit with 8 solenoids and a torque converter. Gear selection is achieved by the control of transmission fluid to operate various internal clutches. The PCM operates the electrical components and provides control of gear selection, shift pressure and torque converter slip.
This transmission includes:
  • Torque converter with an integral converter clutch
  • Electronic shift and pressure controls
  • Four planetary gearsets
  • Two multi-disc holding clutches
  • Four multi-plate drive clutches
  • One one way holding clutch
  • Main control valve body unit
The main control consists of a valve body assembly with solenoids inside the transmission and is controlled by a PCM. The PCM operates the electrical components to provide refined engagement feel, shift feel, and shift scheduling.
Engine power reaches the transmission by a torque converter with an integral clutch. The 10 forward gears and one reverse gear are obtained from 4 planetary gearsets.
The 10R80 automatic transmission is a 10-speed electronically controlled transmission with a main control valve body unit with 8 solenoids and a torque converter. Gear selection is achieved by the control of transmission fluid to operate various internal clutches. The PCM for gas engine applications or the TCM for diesel engine applications operates the electrical components and provides control of gear selection, shift pressure and torque converter slip.
The main control consists of a valve body assembly with solenoids inside the transmission and is controlled by a PCM or a TCM. The PCM or TCM operates the electrical components to provide refined engagement feel, shift feel, and shift scheduling.
My thought on why they haven't issued a correction is it's really a non-issue. You are not losing anything by it not having a 10R80. In fact, we've had more issues with the 80's than any other transmission in the past 12 months. Granted, most is due to software issues, the only difference in description is the 80 can be used behind the light duty diesels and uses a TCM.
One of the main differences is the torque rating of the unit itself. 10R60 is lower than the 80 for itā€™s rated torque capacity, but the 10r80 isnā€™t complaining usually until people exceed 750 or so at the wheels, then the 7th gear direct drive clutches tends to go bye bye. Even with the lower rating Iā€™m hoping the 60 also has a little bit over engineering in it as well.
DesertChip
Chip
Las Vegas, NV
2019 Q5, 2017 GTI, 2007 Porsche Cayman S
The 10R60 canā€™t handle the 2.7L. I heard it on this site, youā€™re all doomed.
Yea, and the brakes are bad too! I heard that on this site as well. Everyone should cancel their orders. I will keep mine for testing and let you know. We show Ford to put out and inferior product.
Jdc
Jon
Massachusetts
Bronco Badlands
Selfless!
Ford Bronco 10R60 Automatic Transmission Specs / Gear Ratios in 2021 Bronco tenor
  • Like
Reactions: abe
MayhemMike
Mercury
I guess this means I wonā€™t be doing low 11ā€™s with the Bronco.
jxc
Joe
Chester County, Pennsylvania
Accord/CX-5/A5 Cab
10R60 has a max torque spec of 600Nm which is 443 ft/lbs
2.7 has a max output of 415 ft/lbs on premium fuel
Ford engineers apparently said that is conservative enough. What happens when you tune beyond 443 ( or 415 ) is an interesting question. 99% of these vehicles will never be tuned. I think we're going to be fine -- of course I may be wrong.
Jdc
Jon
Massachusetts
Bronco Badlands
Where does the 600Nm spec come from? I've tried searching for some official documentation on that but haven't found anything.
NotApplicable
BEVs
Exactly. No one has produced documentation that the production 10R60 in the Bronco is capped at 600nm. Nor has there been substantive discussion about the difference between instantaneous and sustained ratings.
As I stated earlier, these rumors are being propagated by the uneducated and uninformed. One person said it somewhere with no backing evidence, and then a fleet of blind believers have echoed it in every thread on the matter.
Bronco2021RV
Robert
Prescott Valley Az
Acura rdx
You canā€™t be wrong. You put it on the internet šŸ¤£šŸ¤£
hemiblas
Roger
Aurora, Co
17 mustang gt, 3 Wrangler JLs
Do we know what a 91 octane tune does to the torque number on the 2.7. I'm guessing it will exceed the 415 ft/lbs....
Now I'm going to have to carry 2 cans of fuel and a new backup tranny everywhere I go..lol.
jxc
Joe
Accord/CX-5/A5 Cab
I'm taking this wiki( and other sites as being accurate ) and assuming the transmission follows the same naming pattern as the Ford 10R80 (800Nm ) and the 10R140 ( 1400 Nm ) -- but I could be wrong or off. --- Now I'm searchng for the official docs too...
jxc
Joe
Accord/CX-5/A5 Cab
But it's got to be true, it's just got to.
