16 MPH Max Reverse Speed???
badclam
Jefe
PNW
23 Braptor,22 Raptor 37pp,23 F350 CCLB 6.7PS
2021 Black Diamond Sasquatch 2.7. I can only get 16 MPH in Reverse!
Out coyote hunting tonight and had one turn and go behind us. Put it in Reverse, put the pedal to the floor and maxed out at 16 MPH! We had to back up a couple hundred yards to turn around. We lost the coyote of course. We tried again on the paved road thinking the grass was triggering an obstacle governor. The Bronco maxed out at 16 MPH in Normal and Sport mode, 2 and 4 wheel drive.
Looked through the settings, and tried different modes on the road and can only get 16 MPH in reverse no matter what we tried? What am I doing wrong? 16 MPH in Reverse is not acceptable. How do I get past this?
Thanks
badclam
badclam
Jefe
PNW
change the ratio of your reverse gear inside the transmission.
It's being governed. I've got lots of RPMs left.
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Maybe a tune can disable it. It’s governed for safety so people don’t flip it. Mercedes had a recall on the G wagon for that.
drew707
Ford Explorer
The theoretical mechanical top speed is 26 mph in reverse with an auto Sasquatch. But this was using a 5,800 RPM limiter and I’m not for sure on the cutoff point, though that sounds right.
Shane78
Shane
St. Louis
2D
They don’t want you to flip pulling some GTA shiz.
Roger123
Roger
VA Beach, VA
I'm just amazed the speedo works in reverse, these new fangled digital cars are amazing!
Does the odometer run backwards too?
