AH. I see now. I made a typo. Sorry.Interesting, when I bought my wife's OBX non-sas the only other gear option than 3.73 was 4.27.
What size tires are you running when you get that mileage? Keep in mind that changing the tire size is going to change the speedometer, and the vehicle will think you're getting different mileage than you are. Bigger tires and it thinks you're going slower and less fuel mileage, smaller tires and it thinks you're going faster and more fuel mileageNearly exclusively on road, off-road it depends on the terrain.
Mind you, I don't get that mileage on 35's, I tend to get about 19 mpg. 4A Sport Mode using Adaptive cruise control.
True but you can recalibrate the speedometer with ProCal or Forscan to correct for thatKeep in mind that changing the tire size is going to change the speedometer,
You can, but if someone is getting 23mpgs at 85mph with the V6 on flat ground, I'd bet good money they didn'tTrue but you can recalibrate the speedometer with ProCal or Forscan to correct for that
Independent GPS isn't fooled by tire size changes and hand calculation is unphased by that as well.What size tires are you running when you get that mileage? Keep in mind that changing the tire size is going to change the speedometer, and the vehicle will think you're getting different mileage than you are. Bigger tires and it thinks you're going slower and less fuel mileage, smaller tires and it thinks you're going faster and more fuel mileage![]()
Well, considering that you sampled over 8.3 times the distance (including stops) and your mpg drift was 0.9 mpg vs my drift of 0.05 under nearly nonstop conditions on a shorter course... That seems pretty damn good.Calculated by what pump and mileage says and it’s off by almost 0.9 mpg. So about 23.9. 2.7 OBX 2 door 4.27 gear. Stay out off the boost as much as possible. Running 93 no tune.![]()
The stock Black Diamond steelies and General Grabbers would drop my mileage into the 19's with the stock exhaust. Ask me how I know...Dam I don't know how you guys are getting this kind of mpg. I have owned four 6g broncos and never got better than 19mpg. And that was a 2 door hard top black diamond with stock non SAS tires. All my others have averaged around 17.5. 87 octane gas both 2.3 and 2.7 motors all auto trans no sport mode . But I didn't buy it for the MPG
