17 versus 18 inch wheels for bigger tires (37's 38's)?
Darrell
Darrell
Maryland
2021 Ford Bronco Badlands Sasquatch
Which is better 17 inch rims or moving up to 18 inch rims when going to a bigger tire size like 37's or 38's. Is their any benefit to a larger rim?? Also how about width 12.5 13.5 or even 15 any added benefit with wider tires??
Roadbronc
Jerry
Northern ME
2005 Toyota Echo, 2014 Ford Mustang GT
I'd recommend going to 17". Tire choices are much better and in general for especially offroading, the more sidewall height of the 17 is more desired. The tire choices alone is reason enough for me.
Roadbronc
Jerry
Northern ME
I suspect even the 37 and 38 inch choices are better in 17, but haven't researched it.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
You can go to 15" and get some Interco Irok's... lol Not really, I don't think the brake will fit. Would be a cool setup, though.
Roadbronc
Jerry
Northern ME
I would be curious as to how small of wheel diameter that does fit the Bronco.
Roadbronc
Jerry
Northern ME
Perhaps that is the reason the 16 is the base size. :)
mattymik
Matt
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Absolutely, unequivocally this. I have 18” wheels, which I love, but now am stuck with a smaller selection of tires and generally only more expensive options.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
The benefit to larger wheels is the ability to go with larger rotors and calipers. Since you are most likely not doing that, there are more tire choices in 17 as opposed to 18. As far as width, it's personal preference and what you are doing. I prefer a more skinny tire. Some like fat tires.
Roadbronc
Jerry
Northern ME
You could be right, but in general, comparing a 17 and an 18 with the same overall height and width, the smaller wheel combo will be lighter, especially with most factory clunkers.
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
I run method 316s and kenda klever rts... in my case... going with an 18" wheel is absolutely a lighter combo. Not the first time I've run into this phenomenon either... people underestimate the weight of a thick ass sidewall.
