Broncolli
MD
'21 Back Diamond 4 door MIC
You know, at this point I'll take it like that and sort it out under warranty later. Don't need any more delays.
Kind of like a product/manufacturer Stockholm syndrome?
Daktari
Oliver
lol looks like it has moisture issue
sure doesn't look good, that would be unacceptable if that's really water coming in from just washing the thing.
And if it's not water but some what ever from production, also not what I'd expect at what this rig will cost me. How hard can it be to make these things not leak? We flew to the moon decades ago, tupperware has been around for ever, you'd think figuring out how to make a lid seal properly can't be that hard. Maybe Pelican cases should make these instead, LOL.
Hoping for some clarification from the OP here.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
As a fellow Pacific Northwesterner, this is a problem for us...
Yeah but I'm on the dry side of the mountains and I have that sweet washout interior.
If all else fails:
WillisC’onnors
Will
Albuquerque, NM
2021 Bronco (soon)
It’s in the lower left corner. Difficult to see.
Holy cow, I missed it completely. Had to go back. They need to put you on that History channel show where they hunt for Squatch. Hide and seek champion : ended 6/17/21
Oceannomad
Jonathan
SE Virginia
2021 Audi Q7
noliveaxle
john
Riverside, Calif
2015 jku rubicon
Hey thanks for the pictures! Does this still fall under the preproduction excuse? spot #1 - I am hoping the poor top finish is less noticeable in real life. and spot #2 - is that water leaking in ?
looks like some sealant or glue used to install liner. water would be wider drip lines.
Tricky Dick
Dick
PNW
curious how the badges will look with age
I suspect it will hold up pretty well in a picture frame on a desk, which is where I'm leaning right now.
Oceannomad
Jonathan
SE Virginia
2021 Audi Q7
Actually a good idea. Thinking I’ll go badgeless too
Alpha1_Silverback
Alpha1_Silverback
AARON
Ohio
21' Bronco Badlands
Ford Bronco 1st Demo Bronco showed up today! 300px-Phil_Swift_Slapping_on_Flex_Tape
not sure I will dbl check and update. I will have it the entire weekend to shoot some videos
Alpha1_Silverback
Alpha1_Silverback
AARON
Ohio
21' Bronco Badlands
I will dbl check what that is.
DealerInsider
Tom
Horsham, PA
www.chapmannewcars.com
A stolen FE reservation
UhOh
Oregon
Explorer
As a So Cal customer, this is not a concern for us so you can send any Broncos with this challenge that you don't want our way. :)
Nice try, but we are impervious to rain whether its outside or inside ha. Nobody even bothers with umbrellas up here, that's how we know you're not from around here ha. I am not worried about it, its probably not water as somebody pointed out above.
