2.3, Manual, 2 door base model with 37’s?
spookybronco
elise
califrona
Has anyone done this before?
PWillette
Parrie
Maine
If you're talking non-squatch base probably not with a lot of success...gearing would struggle w/ the 37s.
Mike leggiero
Ky
base with a 2 in rc lift 1.5 wheel spacer tires are terramax rt 37 12.50 17 d rate 59 pounds . the blue one is a bd with 2.5 lift same tires. they are skinny for a 12.50. the green is a base 7 speed.
Ford Bronco 2.3, Manual, 2 door base model with 37’s? 1000000796
Ford Bronco 2.3, Manual, 2 door base model with 37’s? 1000000795
Ford Bronco 2.3, Manual, 2 door base model with 37’s? 1000000791
Oldhippie
Barry
Santa Cruz, Calif.
To answer your question; Yes, many folks have done it…
Mike leggiero
Ky
37 on steely base 7 speed
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
@Dusty has that configuration (I think? it may be 35s) and has done a ton of work regearing and whatnot. Good stuff.
Dusty
Mentone, CA
70, 71 & '21 Broncos
Yeah I do have that configuration, with 37's. I re-geared to 5.13 and I believe that gearing is just right. I did run the 37's very briefly before the re-gear, and I found the stock 4.46 gears to be lacking for that tire. I mean, yeah, it's doable. And if all you're looking for is the appearance of the bigger tires and are willing to just live with it being under-geared, I suppose it would be OK and I'm sure there are plenty of folks who have done it and convinced themselves everything is just great.
