Seen many others with this upgrade and results on the 2.3 are trash with Dyno comparisons. There had to to be something else pushing the 2.3 besides the Ford performance tune
Its a cool thing, the added HP and torque. Not something I'd want to install myself. However, he says in the video that there was little or no increase at 91 octane, but that 93 octane was required for the performance increase to kicked in. I dont think the added gasoline cost is worth it to me, although I'm sure some will love it. I assume that you can still run 87 octane efficiently with the tune, and when you need the power, use 93? How does the tune effect MPG?
We initially had the same or worse 0-60 on the 91 octane, only the 60ft improved. We added 93 octane and it completely changed the tune. There are no other modifications to this Bronco. We had same conditions, same spots for both stock and performance tune. We also logged the IAT, MAP and Spark Advance during both runs but didn't post it because the numbers proved the increase. I will try to put something together if anybody wants some more dataSeen many others with this upgrade and results on the 2.3 are trash with Dyno comparisons. There had to to be something else pushing the 2.3 besides the Ford performance tune
I would always run minimum 91 octane with the tune even though the bronco should pull timing if it sees knock but if you drove normally with no WOT it would probably be fine. We haven't done any MPG testing but the throttle response is higher it seems with the tune so it might consume more fuel because it is opening the throttle more with less throttle input.Its a cool thing, the added HP and torque. Not something I'd want to install myself. However, he says in the video that there was little or no increase at 91 octane, but that 93 octane was required for the performance increase to kicked in. I dont think the added gasoline cost is worth it to me, although I'm sure some will love it. I assume that you can still run 87 octane efficiently with the tune, and when you need the power, use 93? How does the tune effect MPG?
That's quick for a 2.3.
Everglades in Wisconsin huh?
You wouldn't think by the numbers it's a big deal but on my 2 door Black Diamond manual, this was the best money I have spent so far. It absolutely scoots, and the Rev matching is SO nice on the manual when off-road, it makes it easy to get down that 2-1 shift at slower speeds. It feels more meaty all over the powerband and here in Western Pennsylvania with all of the hills it's nice having more power.I cant justify that much money for 30hp & 60ft/lbs and thats before driving 140 miles to get 93 octane. Plus the 7MT isnt a racing trans, and WOT isnt called upon too much in these Arizona hills.
I have a 2dr manual badlands, so I'm sure it does help some, but driving to find 93 octane is half a tank away from me, while you might have easier access to it. The joys of living in an Arizona border town are plentiful, but high octane fuel isnt one of them.You wouldn't think by the numbers it's a big deal but on my 2 door Black Diamond manual, this was the best money I have spent so far. It absolutely scoots, and the Rev matching is SO nice on the manual when off-road, it makes it easy to get down that 2-1 shift at slower speeds. It feels more meaty all over the powerband and here in Western Pennsylvania with all of the hills it's nice having more power.
There might be more to it than just peak numbers/curves. We can tell that the factory tune is set up extremely soft to protect the fragile axles and drivetrain components. A WOT dyno chart wouldn't show that. Given the weight and horsepower numbers, the Broncos are much slower than they should be. If the tune tightens up the shifts and allows more power in more places, the truck would get faster even with the same peak numbers, because the ECU spends so much time not at peak numbers in order to protect the drivetrain.Seen many others with this upgrade and results on the 2.3 are trash with Dyno comparisons. There had to to be something else pushing the 2.3 besides the Ford performance tune
I run 93 all the time, I'm still sitting at 19 combined which is mainly back roads with some highway. If I lost some it would still be worth it for the driveability improvements.What octane gas do you run? Have you noticed any significant increase in fuel consumption?
Yes, much more peppy (esp. in a 2 door manual) with gains as follows for the 2.3L:Does it feel more peppy during normal driving and acceleration or just wide open runs?
