2.5" Lift - not so expensive afterall
AcesandEights
Ace!
Oregon
2016 or 2017 Ford
I was just looking at quality (best quality ever made in this world or next, the best on nine planets) lift kits for the Ranger and see you can get one for less than $1,500. A 2.5" OME lift is only $1,400 and anyone with a shade-tree should be able to park the Bronco and install it. Includes shocks and springs for 2.5" lift. Anyone can run 35"+ tires, even the base folks. I'm guessing the Bronco system will be similar!
Advertisement
Razorbak86
Northwest Arkansas
Lexus RX-450h, BMW R1150 GS
Is this the one (Old Man Emu)?
https://arbusa.com/ford-ranger-2019-on/old-man-emu-4x4-suspension/
https://www.polyperformance.com/ome-2-5-suspension-lift-kit-for-19-ford-ranger
AcesandEights
Ace!
Oregon
2016 or 2017 Ford
Yeah
North7
North Texas
Bronco Badlands
Nope, new chassis
Razorbak86
Northwest Arkansas
Nope, new chassis
I think the operative word from @AcesandEights was “similar”, not “identical”. I’m sure it will be a kit customized for the Bronco chassis, not simply a rebadged Ranger kit.
AcesandEights
Ace!
Oregon
2016 or 2017 Ford
I've used OME in the past and really like them. I was glad to see a reasonably priced kit for the Ranger, because it probably means it wont be a blinged out $3k kit for the Bronco, like some of the other companies.
Razorbak86
Northwest Arkansas
My definition for a lift kit for IFS involves a differential drop and larger/longer knuckles.
Understood. People have different personal preferences. Some enthusiasts refuse to buy a Bronco or a Jeep unless it has a V8 engine, which is perfectly OK, because they’re talking about the vehicle they want to drive.
From a practical perspective, though, it really depends on the intended use case. If you’re planning to bash around Moab or Johnson Valley with 37” tires, you may want a diff drop and new knuckles. However, if you want a marginal increase in ride height and are just tying to improve ride and handling quality, then an OME lift is probably a decent upgrade.
Fedexman1978
Kansas city
Honda Accord
From a practical perspective, though, it really depends on the intended use case. If you’re planning to bash around MOAB or Johnson Valley with 37” tires, you may want a diff drop and new knuckles. However, if you want a marginal increase in ride height and are just tying to improve ride and handling quality, then an OME lift is probably a decent upgrade.
There's always that one guy in every bunch that must poopoo your idea, and one up someone. This is good news no matter. Thanks for sharing.
Gamecock
2011 FJ Cruiser
That shouldn’t define a lift for most people though...most IFS trucks are fine with a 2-3” lift over stock with no diff drop needed. You don’t want to drop the diff unless needed by extreme angles created.
AcesandEights
Ace!
Oregon
2016 or 2017 Ford
To each their own. I wouldn't add a lift if I had to lower the ground clearance.
North7
North Texas
Bronco Badlands
No one is poopooing the idea. It's guaranteed there will be at least a dozen aftermarket lifts the first year.
The OP thought the Ranger chassis was like the Bronco chassis, it is not, and I explained that in pictures.
Of course you knew all of that, and how users help others out here on Bronco6g.
Hoofnmouth
mark
N ca
ford focus st
It is a great option for some one who likes the lifted look and doesnt care about the mechanicals ,cheap way to go / base no squatch 2.5 lift 35s bingo.
That is what i was going to do before they offered base squatch manual
Advertisement
Wide Open Roads
Advertisement
