I know. He’s got an oil producing truck.He got 6.75 out, that's not the problem.
i don’t think any of that is good info. First, the more oil you have the better it doesn’t overheat. Yes the difference between high and low is 1 qt. As far as running low, I had a 2003 GMC envoy with 4.2l inline 6 which was a good engine. At the time I used to keep my oil level at the halfway mark on the dipstick which was a 1/2 quart shy of the vehicle specs. If my oil ran a little below half In the hills in West Pa my engine would run dry and start fluttering like it was out of oil. Ever since I try to keep my oil level as close to full as possible, which by the way is the level when you fill all cars to spec afaik.It may have been mentioned but, between the low mark and the full mark on the dipstick is usually 1qt for American vehicles and 1L for non-American.
Also, the "low mark" should be thought of "the least amount of oil for all operating conditions" such as going up or down a steep hill.
Unless you've got an oil burner, running closer to the "low mark" is better than being at the full mark as all oil protects the best at operating temp. The less oil you have, the faster it will get to operating temp. How much would this really help in the long run for your engine, IDK but, it won't hurt.
I've always run all my vehicles just a quarter above the low mark and check the level every two months.
