2.7 Question - See Photos
broncoky
Jacob
Lexington, KY
2021 Bronco 2DR CB OBX SAS & 2000 Lexus LS400
Question for the more mechanically inclined members…
I was poking around under the hood last night and noticed this. Should it be connected where the bright light is focused or is it just some type of stop/bumper?
I tried to move it but it’s very rigid And don’t appear to be flexible.
Can someone with a 2.7 check and confirm?
Advertisement
Wanted33
Down south in Dixie
Vehicle Showcase
I'm not sure what I'm looking at brother. Is it the hose's we're talking about?
Virtual-Chris
North Vancouver
I dunno but there’s a tear in that black boot in the photo. What is that?
broncoky
broncoky
Jacob
Lexington, KY
Take another look. I circled the area in question.
noliveaxle
john
Riverside, Calif
2015 jku rubicon
Boot is twisted like it was shown to be on other posts. That black block looks like an insulator. I’m guessing to keep wiring a distance from the engine.
Advertisement
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
broncoky
broncoky
Jacob
Lexington, KY
Thank you!
To me, it looked as if something had come loose and freaked me out a bit.
I knew someone here would know!
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Thank you!
That silver surface that you circled with a hole in it in your 2nd photo is likely just a positioning lug on the side of the passenger's side cylinder head on the engine. It is probably used to hold the position of the casting before the internal surfaces are drilled, tapped, and machined.
I took a photo of a similar lug on the driver's side cylinder head of my engine (below right), using an automotive extension mirror to show that the surface of the lug is not mated to anything, drilled through, or tapped for threads, so it's sole purpose is likely for positioning of the casting prior to machining. Next to my photo (below left) is a photo from an F-150 2.7L Ecoboost engine block on eBay.
Below is a 3D drawing showing the same lug relative to the other engine components. All items circled in red appear to be the same positioning lug.
broncoky
broncoky
Jacob
Lexington, KY
Thank you for the thorough explanation! Much appreciated!
Advertisement
