2.7 Underboost condition ..please check the Charge Air Cooler Hose connection
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
Had a couple of codes come up going up long stretch of hill going about 75 mph ....Bronco went into limited power mode.
Took to dealer and results came in and fixed.
the Charge Air Cooler Hose was barely attached to the Charge Air Cooler Pipe..so it was basically sucking air.
Good news is I thought the Bronco had really great power, but now that I have full boost...wow!
Can’t wait to see if it helps on miles per gallon.
Ford Bronco 2.7 Underboost condition ..please check the Charge Air Cooler Hose connection 9C12C0AC-6585-49AF-8FD1-5E977FF423A2
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
'79 Mustang, '92 Explorer, '10 F-350
Probably wasn’t ever really connected properly. Did you hear a big bang coming from under the hood? When I blew an intercooler hose on my F-350 it was so loud I just about jumped out of my skin.
BroncoBuckaroo
BroncoBuckaroo
Joe
Missouri
could be ..I never noticed it ..looked at the engine a couple dozen times
BroncoBuckaroo
BroncoBuckaroo
Joe
Missouri
no..not that I recall but I might have had the music up loud a couple times
bytheway
Brice
Louisville, KY
What was your mpg before? I’ve been below 17 average the whole time and wondering why I’m worse than advertised.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Is this the air charge hose that's being used to hold the coolant hose away from the pulleys? Asking for a friend đź‘€
Paul Gagnon
Paul
Hmmm… I guess that’s the difference in boost pressure of 12 psi in the Stealth, 18 psi in the Bronco and 38 psi in the 6.4.
Toccoa
Isuzu Rodeo Sport
What is it with stuff under the hood not being properly secured at the factory? Glad you were able to get it fixed. (y)
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Can you describe where the Charge Air Cooler Hose and Pipe are? Maybe take a pic? Is it easily accessible; can we find this issue during delivery acceptance?
Jdyount
Kansas
2021 Badlands
The intake lines (blue) take in outside air and run it to the turbos. The turbos then charge, or compress, the air and feed it into the charge air lines (red). These lines run to the intercooler (yellow), which cools the charge air, then from the intercooler to the intake.
The intercooler is up front directly behind the front bumper. My bet is that's likely where the bad connection was given the other portions of the charge pipes are move visible.
Ford Bronco 2.7 Underboost condition ..please check the Charge Air Cooler Hose connection 1638358547154
Ford Bronco 2.7 Underboost condition ..please check the Charge Air Cooler Hose connection 1638362140767
BroncoBuckaroo
BroncoBuckaroo
Joe
Missouri
I will try this afternoon ..after I get off work
  • Like
Reactions: Cat
BroncoBuckaroo
BroncoBuckaroo
Joe
Missouri
The intake lines (blue) take in outside air and run it to the turbos. The turbos then charge, or compress, the air and feed it into the charge air lines (red). These lines run to the intercooler, which cools the charge air, then from the intercooler to the intake.
nice explanation
BroncoBuckaroo
BroncoBuckaroo
Joe
Missouri
good question, unfortunately I wasn’t at the dealership when they repaired..I’ll reach out to the mechanic and see what he says.
