More like a broken valve head, the critical junction being closest to wear the valve head meets the valve stem and is at its thinnest point. Improper metallurgy/tempering/heat treating can result in a brittle valve which hardens further under multiple heat cycles, eventually leading to failure.I haven’t read all this thread but I hear everyone saying they dropped a valve. How would a bad batch of valves cause a dropped valve? Could keeper/retainer notch be bad and not lock in the keepers? Could the valve break at the keeper/retainer notch? Is it really the (6518) in the diagram actual valve keeper/retainer that failed to keep the valve, thus dropping into cylinder? Or the rocker could kick off due to bad lash adjusters (6500) causing it to hit the spring, which could throw the retainer and drop the valve? This was an issue on some 5.4’s. Only so many parts can cause a dropped valve but it usually isn’t the valve itself that failed.
