2.7L Bronco Engine Oil Change How-To DIY Video
RagnarKon
Ford Bronco, Escape, Focus
Nice.
So we got hard to reach oil filters on the 2.3L and plastic composite components on the 2.7L.
I think the plastic has been around for awhile at this point… so I’m sure they’ve gotten all of the kinks out and it’s more or less fine. But I sure would feel more comfortable if it was metal.
tjnoffy
Jay
Maryland
'21 Bronco OBX Sas, '05 Mustang GT Conv, 2 Harleys
Nice.
I think the plastic has been around for awhile at this point… so I’m sure they’ve gotten all of the kinks out and it’s more or less fine. But I sure would feel more comfortable of it was metal.
I'm just glad my oil filter will be on top! 🥳
termin8
Ontario, CAN
2013 ford edge
That was a good video, and would also take my time as the presenter did, but if going to your dealer, do you think they will wait the time for all the oil to drain out, put only 6 quarts back in, replace those 3 nasty o-rings and replace all the bolts holding that cover plate back on underneath ??
evilletruck
evilletruck
Evansville IN
2006 F350
Does doing your own oil change void any of your warranty?
No, but you need to keep your receipts to be able to show that they were done. just in case they try saying what ever warranty work is related to you not changing your oil at recommended intervals.
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
So what's the point?
evilletruck
evilletruck
Evansville IN
2006 F350
To have clean oil? If you go to anyone else for an oil change, you will need to keep the receipts as well for the same reason.
VelocityBrew
Every 1000 miles per the owners manual, right? 😂
Or you could take it to the dealership and never worry about keeping track of receipts and having a customer folder in case of warranty issue.
evilletruck
evilletruck
Evansville IN
2006 F350
Only did it after 1,000 for break in, wasn't called for in manual but old habits and all. but I did say I would normally do it every 5k per the manual. I still keep receipts even if the dealer does it. Things have a magical way of disappearing if they are left to other people to look after.
GrabberBlue
Phoenix, AZ
2010 F-150 Raptor, 2021 Bronco FE
If you go get your oil changed right now you'll have an engine overfilled by 1 quart because all the materials are calling for 7 quarts. Do it yourself until Ford sorts out this misprint mess.
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
Great video thank you. Did you check the oil level after running it? Did it drop significantly ( like a whole quart??LOL)? It always pains me to see a metal tool used for o-rings. LOL. I'm sure these seals aren't too particular about it. Plus it's a double o-ring design so that should help if the sealing surface gets scratched.
