2.7l Engine “residue” question
Alvin Olson
Alvin
Houston, TX
2014 Ford Raptor - 2017 Ford Raptor
I noticed a stain or oxidation on The top of what i assume is the throttle body inlet. I could just clean it, but curious what it might be.
~ 1500 miles.
VVSidewinderVv
Tim
Pittsburgh, PA
20 GMC Sierra
Did you try tasting it?
In all seriousness my guess would just be dirt/ mud. Unless it's greasy I wouldn't worry too much. Might be worth pulling that MAP sensor to make sure it's not caked in it if it is greasy.
Alvin Olson
Alvin Olson
Alvin
Houston, TX
I’ll pull the MAP and check. My guess is some sorta condensation.
VVSidewinderVv
Tim
Pittsburgh, PA
20 GMC Sierra
The other possibility is water mixed with oil leaking through the clamped connection right there. It's right downstream of the PCV system. I'd make sure that connection is tight.
Alvin Olson
Alvin Olson
Alvin
Houston, TX
Looks like it was coming from the throttle body or at least leaking from there.
Ford Bronco 2.7l Engine “residue” question DA73E1D9-D0B3-4B76-A0B1-0CD07B64054F
I cleaned it best as i could as it was very dry and crusty. Not oil. Most likely condensation leaking from that clamp.
I had to use MAP cleaner and steel wool to remove it then some rubber restore to make it look nice again.
i then moved the clamp a bit closer to the edge and tightened it within reason.
i will keep an eye on if it returns.
Ford Bronco 2.7l Engine “residue” question 0424DA74-F366-4451-AB4F-43333A164E04
Ford Bronco 2.7l Engine “residue” question 51D11EAF-687C-4725-963D-3A4E6A78641C
