Lake Tahoe Traveler
Sf Bay Area, CA
2022 Bronco 2dr BL SASQ, & 1975 Bronco Ranger
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
It locks with the spring wave. The spring wave makes it more solid in my opinion than the factory plug which just quarter turns and has no tension.
Ford Bronco 2.7L Oil Change Tips + Replacement Drain Plugs F0492CB8-C10E-4FBD-961B-D021AB15F4F4
The two tangs on the factory plug snap into grooves to keep the plug from backing out under vibration. I was curious if the Ronin plug was anti-rotated as well, or just held in with the spring load. Really prefer a mechanical locking method vs. friction locking.
I've noticed that the UPR plugs and other aftermarket plugs are anti-rotated like the OEN plug.
da_jokker
Jeep Wrangler JKUR
Laura Z. Wrote an article for Bronco Ford spec fluids…
https://thebronconation.com/the-recommended-fluids-filters-and-components-of-the-2021-ford-bronco/
According to Ford they specify 5W-30 WSS-M2C961-A1.
So whatever oil you chose make sure you see the Ford WSS-M2C861-A1 spec that meets or exceeds this specification.
Ford via Bronco Nation article for all fluids
I still can't get over how they recommend a synthetic blend instead of full synthetic. It seems like the consensus is to go full synthetic. Wish I knew it was simply cost cutting or there was more to it.
OS Bronco
Ocean Springs, MS
2023 Wildtrak
The installation instructions call for inserting the Ronin plug with a groove it has in it at the 7 - 8 o'clock position then rotating it clockwise to 12 while pushing it in. It sits the same way the original plug does, but uses the spring washer to ensure that it won't vibrate out.
Happy
Jerry
Missouri
CJ5, Wagoneer
Resurrecting this thread to ask the early users if they are still happy with their aftermarket oil drain plugs.
So, are you still happy with your aftermarket oil drain plugs? I was planning to just reuse my factory plastic but since it needs to be replaced sooner than later, probably going with an aftermarket. Those who do shorter interval oil changes will end up saving money with a better plug. So the question is, IS your Plug working OK?
Really hoping to hear about the Fumoto (?) that is being beta tested.
Lucky Nut
Memphis, TN
97 TJ
I installed the Ronin plug during my first oil change. Seems to be doing the job. No leaking. I haven’t gotten to change #2 yet so I can’t really give a good answer, sorry. I’m excited at the idea of that oil not coming at me at 100mph.
broadicustomworks
Hanging Rock, North Carolina
I just did my first change. And boy did that factory plug (with hot oil) real make a helluva mess.
Installed the Ronin, was concerned because it doesn’t “lock in” like the factory, seems a bit loose but I’m trusting the spring washer to do what it is designed to do.
no leaks while run testing, so should be fine.
still makes me nervous though!
Ford Bronco 2.7L Oil Change Tips + Replacement Drain Plugs 2C995ECC-E106-4D6A-8BBB-95419A8A139E
buzpro
Binky
Tacoma
The Ronin plug should not be loose, so if you can, tighten it hard by HAND only ... the spring is supposed to crush .... the only reason to take it off later is to see if the magnet has caught any metal shavings, otherwise its install and forget.
If you do take it off, make sure you order a new spring before doing it.
my 2 cents
Due51
Bronco, Silverado
Well I wish I found this thread before I did my first oil change.
I opened the filler cap, removed the skid plates, drained the oil (made a mess), opened the oil filter housing, then let it drain for half an hour.
I put in 6 quarts of Amsoil OE full synthetic 5W-30. After 10 minutes, I flat foot cranked it anf checked the dipstick which was halfway in the hatch. So I added more. Whoops. After driving it for half an hour, I came home, shut it down, let it set, and checked again. WAAAAAAY overfilled. Had to drain out about a quart and a half.
I'll check it again tomorrow morning.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I would do some research. At least one thread here has reported a 7qt fill and that the full reading is above the hash marks (in the “twist of the dipstick). I did the 7qt fill and came up with the same mark on my dipstick.
BRBlue
Houston
Toyota Tundra
Mine was over the top hole “max“ mark and into the twist from the factory. Drained and measured 7 quarts came out. Put 7 quarts back in.
Mattwings
Matthew
Northville, MI
Ford Bronco 2.7L Oil Change Tips + Replacement Drain Plugs B67BFF1E-DFF2-421A-99DA-43439CF552F0
Similar here. I think it’s the right level. I have had no obvious adverse effects.
Due51
Bronco, Silverado
I just added a half quart (meaning I've put in 6 quarts total) and the oil is above the max fill hole. As others have said, I've changed a lot of oil in my 56 years and never had to arm wrestle a dipstick like this.
Ford Bronco 2.7L Oil Change Tips + Replacement Drain Plugs E7BBB6ED-7DA7-4631-903A-D010BC1D16DE
buzpro
Binky
Tacoma
6.5 qts should be good ...... unfortunately you cant go by the dipstick Ford has suppled with the Bronco
buzpro
Binky
Tacoma
I wonder if they changed the dipstick on the 22's or if they will keep ignoring their customer base
