Yeah, but I think you are drawing the wrong conclusion from the limited MT offerings here in the U.S. Up until 2018, Ram offered a manual in the 2500 diesel; the Cummins when paired with the MT produced 650 lb/ft of torque (I know I'm referencing a heavy duty truck, not a light truck that you are talking about). It didn't sell well, but I'd argue that this was - in part - because you could get a Ram 2500 with something like 850 lb/ft of torque when paired with a 6-speed auto, and around 930 lb/ft of torque in the high-output version of the Cummins found in the Ram 3500 (mated to an Aisin auto). Just like with the new Bronco - a buyer would have to opt for the lower-powered vehicle to get a manual. That will drive many buyers away from the manual. But my real point is that manual transmissions can be built to handle high torque. We also see manuals capable of handling high power in sports cars like the hell-cat powered Dodge Challenger (700 lb/ft), the Dodge Viper (600 lb/ft), the Audi S4 (369 lb/ft), the Audi R8 (406 lb/ft), some BMWs, etc. Again, I know these are not light trucks (and some are no longer in production), but these are examples of high-powered manual transmission vehicles sold in the U.S. So, there is no technical obstacle to putting a more robust MT in the Bronco that could handle the 2.7 engine. From the beginning, if Ford had sought to develop a manual transmission that would work with both the 2.3 and the 2.7, the investment would not have been significantly different than developing a manual option that would only work with the 2.3, and the end-price for the consumer would be a bit more than the current manual ($1,000 more?), but still lower than an auto transmission.“Close range transmission”
The 7 speed ford has. Is 6.615 range excluding the crawler. 10.154 range with the crawler.
Close range means 5.0 range or smaller. Meaning sure you’ll get the low gears but likely no OD. Meaning bad high way milage. Meaning won’t pass EPA standards.
It’s not just about “engineering” a transmission to handle the power. (Which any additional cost would be passed on to customer). It’s also about passing EPA testing. Which cost a lot of money. Roughly $20,000 EACH test.
Add all that up. Now ford would have to charge MORE for a manual than an automatic transmission for the 2.7. Cutting down the take rate even more.
All and all it’s just not worth fords time
Just like to point out. You CANNOT get a light truck or any SUV with a manual with over 300lbft in the USA. Aside from the bronco.
Bronco 310lbft
Frontier 281lbft (special order only may be gone for next generation)
Wrangler/ Gladiator 260lbft
Tacoma 265lbft
Crosstreck 176lbft
That’s all you can get if you don’t want a sedan/coupe manual in USA.
But I think you are probably correct - Ford will not produce a Bronco with a MT 2.7
