2 door aftermarket Soft Top options?
rsmag9
Rob
Ford's
Has anyone seen any info on aftermarket 2 door soft top options yet? I assume the fastback style one that we've seen on the test mules will be available but I was really hoping for soft top that folded back at least as far as the stock 4 door soft top. I'd also be interested in a bimini/bikini top but the only one I've found is the mesh one.
Stampede.Offroad
SD
junk
I bet you could wrangle one of those $5 blue tarps onto it.
stuckinohio
Columbus Ohio
2 Door Badlands, MT High 2 Dr, V6 Outer Banks, Lux
You can add the Bestop soft top onnthe B&P, unless it recently disappeared.
I'm assuming Bestop is not ready to produce them yet though. They are super slow.
stuckinohio
Columbus Ohio
Just looked on Bestop site. They don't have the Bronco listed yet.
tferg
Terry
Calgary Alberta Canada
1969 Ford Bronco
If you search the Filson Fire rig build, it had a better Bimini top. It seal the front cab but sill was a Bimini
Ford Bronco 2 door aftermarket Soft Top options? Filson-Bronco-Wildland-Fire-Rig-Concept-2
without bows. I hope this becomes available for the 2 door with a windjamer and tonneau cover. Would be the perfect summer set up.
rsmag9
rsmag9
Rob
Ford's
Gotta buy from a Ford Dealer
I'm not a big fan of the fastback top but it does look like you can find them through dealerships. Some dealers are discounting them but I'm not positive if they are in stock or not. Part number for the nicer twill version is VM2DZ-54501C24-F
Headsong
Best Top is under licensing restrictions for a time, no one knows how long...before they can produce an aftermarket top under their label.
peterh
ny
jeep wrangler jlu 2018
i just hope someone makes a top that goes all the way down on the 2 door. in off white.
Cindylou15
Cindy
Woodstock
[100 percent!!!
I’m still waiting for the Windjammer, bikini and tunnel as well
QUOTE="tferg, post: 749353, member: 17643"]
[/QUOTE]
