- Jul 24, 2020
- 70
- 5,019
- 18,565
- Up Doug's ass
- d
- Raptor
Do you have the candela output and also load ratings of the roof that you would like to share?ZROADZ’s Roof Rack for the New Bronco is a great addition for Bronco owners looking to mount a rooftop tent for cross-country trips or weekend getaways. This complete kit includes a ZROADZ Roof Rack, crossbars and a set of ZROADZ high-powered LED lights, and a custom wiring harness. The ZROADZ rack is a modular design that ships to your door and includes all necessary hardware for an easy install by utilizing factory mounting points. The included step-by-step instructions help you accomplish the complete install in just a few hours. A key feature in the design of the ZROADZ roof rack is the adjustable dual crossbars. These adjustable dual crossbars allow for most soft- or hard-shell tents, small or large to be positioned throughout the rack. Included in the kit is a complete front and rear-facing LED light source with (6) 3-inch White ZROADZ LED and (2) 3-inch Amber ZROADZ LED Pod Lights, (1) 30 Inch ZROADZ LED Single Row Light Bar, and a wiring harness. The ZROADZ roof rack is made from 1.5-inch round tubing, heavy gauge mild steel crossbars and comes standard with a 3 Stage Epoxy Based Black Powder coated finish. The ZROADZ Roof Rack for the Ford Bronco comes with a Limited 3 Year Warranty against Material and Workmanship and a 1 Year on the Finish.
Features & Benefits:
- Modular Roof Rack with Crossbars
- Available with (6) Forward facing 3 inch White and (2) Amber LED Pods, mounting brackets, wiring harness with fusible link, relay, toggle switch, and all necessary hardware
- 1712 Lumens, 20 Watts, CREE 5W LED Chips per pod light and 14,652 Lumens, 150 Watts, CREE 5W LED Chips per LED Light Bar
- Includes all necessary hardware and step by step instructions
- Heavy Gauge Mild Steel Construction, 1.5 inch Round Tubing and Mild Step Crossbars
- Low-Gloss Textured powder coated finish
- Easy, bolt-on installation, no drilling required. Installs in less than 60 minutes with basic hand tools.
- Accepts most soft- or hard-shell tents
- Covered with a 3-year warranty against material and workmanship, 1-year warranty on the finish, Limited Lifetime Warranty on the ZROADZ lights
- Manufactured by ZROADZ Off-Road Products in Corona, California. Made in the USA
