- Feb 21, 2020
- 105
- 7,033
- 24,806
- North Texas
- SUV
- Undecided
Are you debating a Solid Axle Swap (SAS)?
/s
/s
I look forward to seeing the innovations that will stem from those posts being in there. I have a feeling they're going to come in handy.They can be removed, but there are posts sticking up from the load floor that cannot be removed.
This is my Bronco ordered almost exactly. I didn't get the optional wheels because they are $1K more, but man, do I really like how they look. I don't need beadlock capability, so that $1K would be entirely for looks.Just managed to check out a non-sasqutched Badlands at a local dealer in Arizona, and wow, to say I was impressed is an understatement.
The 2 door looks way bigger in person than it does in pictures and I think under most circumstances, the cargo room should be totally fine. The rear space leg room is adequate and I was able to sit behind myself with plenty of room. It has noticeably more cargo space and leg room than a 2 door wrangler. The 33’ inch tires seem perfectly portioned for the 2 door, and in my opinion you don’t need Sasquatch on this trim.
One moderate accident later and the rear seat and it's occupants are visiting the front seat occupants.Exactly. It’s a pretty simple project really. Cut off the studs level with the floor pan, weld bungs in the original locations, clean with a wire wheel and some solvent, and apply touch-up paint to match the floor pan. Then you can re-use the studs that were cut off if/when you want to re-install the seats or simply sell the vehicle.
VIDEO!
What can I say? I like to build things, and I’m pretty good at it. I’m a mechanical engineer, I own a welder, and I know how to use it. I can design, cut, brace, and weld that connection stronger than the factory mounting that you’ll find underneath the seat of your delivered Bronco. It’s really not rocket science.One moderate accident later and the rear seat and it's occupants are visiting the front seat occupants.
I would definitely want to know of someone did that mod to a used vehicle I was buying.
Building things is great. Engineering things is important. My comment was about cutting off a bolt that went through the sheet metal and was through-mounted into the frame and replacing it with maybe 1/2" of threaded support.What can I say? I like to build things, and I’m pretty good at it. I’m a mechanical engineer, I own a welder, and I know how to use it. I can design, cut, brace, and weld that connection stronger than the factory mounting that you’ll find underneath the seat of your delivered Bronco. It’s really not rocket science.![]()
Damnit man, leave some clecos for the rest of us!What can I say? I like to build things, and I’m pretty good at it. I’m a mechanical engineer, I own a welder, and I know how to use it. I can design, cut, brace, and weld that connection stronger than the factory mounting that you’ll find underneath the seat of your delivered Bronco. It’s really not rocket science.
I can build other things, too, like the horizontal and vertical stabilizers below for the tail of an aircraft, and the workbenches they’re mounted on, and the air piping system throughout the garage. Some of us like to build things.
Seats don't bolt to the frame. They generally bolt to nuts under sheet metal that's about twice as thick as the surrounding body sheet metal. 1/2" of thread engagement sounds about right for OEM. There are always liability questions but this can certainly be done safely if one understands materials.Building things is great. Engineering things is important. My comment was about cutting off a bolt that went through the sheet metal and was through-mounted into the frame and replacing it with maybe 1/2" of threaded support.
There's certainly more than one way to do things and you seem more than capable of making something that works for you. I'm the type that prefers to avoid irreversible modifications. But I'm not planning of removing the rear seat, so I don't even need to even consider what I would do.
The studs that the seats are mounted to are 12mm in diameter (less than 1/2”) and are called RivStuds, which are studs that are riveted in place during fabrication.Building things is great. Engineering things is important. My comment was about cutting off a bolt that went through the sheet metal and was through-mounted into the frame and replacing it with maybe 1/2" of threaded support.
@Razorbak86 you have a number of cool projects there, nice shop, nice work, I see you cornered the market on clecos, now will your install pass the aircraft seats 16g sled test?What can I say? I like to build things, and I’m pretty good at it. I’m a mechanical engineer, I own a welder, and I know how to use it. I can design, cut, brace, and weld that connection stronger than the factory mounting that you’ll find underneath the seat of your delivered Bronco. It’s really not rocket science.
This is great information and gives us a more accurate depiction of the room in a 2-door. Thank you so much!VIDEO!
No problem! I was really curious about it myself and torn between a 2 door and 4 door. While I'm still torn, the one thing I will say after seeing both in person is right when I saw the 2 door badlands in person the first thing I thought was "damn I need that". I didn't get that feeling with the 4 door even though it's more practical.This is great information and gives us a more accurate depiction of the room in a 2-door. Thank you so much!
Earnhardt Ford. I don't think it was a part of the dealer preview it was just a marketing rep working his way through the dealerships.Which dealership was lucky enough to get the 2-door??? I am super jealous!
Jim Click in Tucson only got 4-doors. A black Outerbanks with leather and lux package, and a Cactus Gray Black Diamond, manual with stock steelies.
I was pleasantly surprised to see that the stock 4-door cloth top folds completely down like a proper convertible.
