The good thing about the Goose Gear setup is that there's a panel right behind the passenger and driver seat that's vertical that adds a great deal of structural support across the span from driver to passenger side. I used that vertical piece to attach my safety jack base plate too on the passenger side, and my smittybilt compressor on the driver side. The other cool thing about the goose care setup is for the rearward part of the panel, you remove the entire OEM floor piece...and with the spacers to level out the entire floor you gain about an inch of height over the cubbies which allows you to put more stuff in them. The reason I morphed from my do-it-yourself set up to the goose gear setup is because the goose gear setup already came with a waterproof coating on it, and cutouts for the cubbies, and it was already cut to the exact dimensions it needed to be. I know that there's woodworking folks and other people out there with all the equipment that could do it out of other materials, or would, and do a much better job than I did, but the Goose Gear as expensive as it was did save a lot of time (to clarify it was the second platform they sent me that saved time...the first one was in drastic need of modifications). I ended up throwing a giant yoga mat over the whole shebang anyways, so no one would be able to tell the difference between the $1,000 Goose Gear setup and the do-it-yourself first attempt. The important part for either setup is having the exact correct height spacers and the correct locations for those spacers so that the floor doesn't flex (and pinch things like the windshield washer line). With the spacers I was able to disconnect the seat belt receivers from their brackets and they fit well without interfering with the underside of the platform.I am definitely taking out my rear seat. Currently 50/50 on deciding between Goose Gear and DIY. Watching all these threads with interest.
