Go 37s , if not you'll always be kicking yourself for not doing it.Im going to try the 1.25" level kit from ready lift while im waiting for my ads 3.0 shocks to be built.
my thinking is that the lower ride height with -12mm offset beadlocks will better suit the desert runner look im going for.
still debating on trying a true 35" nitto like the 4600 broncos, or going straight to a 37"...
Absolutely I would I love the lookBeautiful! If you were to do it all over again, would you keep the same offset? -12 is probably one of the most aggressive on a Bronco so far!
Front is a kicker key 200.4 see photo. Amp is tied into oem front speaker channels. Sub is also tied into those and is powered by a key 500.1 its mounted in the cuby under the floor. Sub is a kicker shallow 12 using straps to hold it I'm for easy removal as neededInterested on the details of the amps install, please. I was considering those amps because I thought there would be enough room under the dash to install them. Did you use an LOC or just the high level inputs? Did you use an aftermarket harness or splice the factory wires? I don't have my Bronco yet, but hopefully soon. Pics would be great. Please feel free to DM. Thanks!
I debating doing the same setup, but I think it's going to be too much. I'd like to take about 3/4-1" off the RPG.Thoughts on the RPG lift with 35s? How do all of you think that will look?
Is that with the steering column all the way down? Looks like its close to hitting in this pic.Front is a kicker key 200.4 see photo. Amp is tied into oem front speaker channels. Sub is also tied into those and is powered by a key 500.1 its mounted in the cuby under the floor. Sub is a kicker shallow 12 using straps to hold it I'm for easy removal as needed
That is all the way down it does not hitIs that with the steering column all the way down? Looks like its close to hitting in this pic.
One of the best builds I've seen yet. It looks (and I'm sure it SOUNDS) amazing. Well done!Just finished my getting the Bronco on 37 tires. So far so good no rubbing seems to ride a little better than with the stock Goodyears.
Full specs / mods:
2022 Bronco Badlands Sasquatch 2.7L
RPG Spring Perch Lift https://www.rpgoffroad.com/product/bronco-spring-perch-collar/
17x9 -12 offset Vision Nemisis
37x12.50x17 Ironman Mt
Vision 17x9.5 -12 Wheels
4wp track bar
Rough Country spare reinforcement
Stereo:
- Kicker key 200.4 powering 2 kicker KS 6.5" and 2 KS 4" up front
- Rear kicker KS 4 inch factory powered
- Kicker key 500.1 powering a kicker comp rt down firing shallow 12.
