Georgia 2-dr Bronco? I've found the solution for storage and towing...
LoboDelRio
Payne, GA
2021 BaseSquatch, 2015 Tacoma
Saw this on the road today. Man, those Jeep guys really have figured it all out. I wonder if the Bronco is rated for this !!! :LOL:
Ford Bronco 2-dr Bronco? I've found the solution for storage and towing... Jeep_2Hitch
MaverickMan
Shane
I got my doubles and triples endorsements, we can do this thing!
I did pull a jeep and a small trailer across town once behind my van. It works... kinda. Just cant back up or the caster will get ya kink'd.
LoboDelRio
LoboDelRio
Payne, GA
Yeah, I've seen double hitches before, it should work. But welding hitches to those luggage carriers? Those things are rated for what, 400 lbs.? I mean, judging by vehicle age obviously this guy has it working, but I would love to see Ford engineers take a whack at calculating these loads/stresses.
Rick Astley
Up Doug's ass
d
I'm betting the Ford lawyers would be getting the first crack at determining the loads/stresses from a setup like this well before the Engineers were approved to spend a second on it.
:ROFLMAO:
MaverickMan
Shane
For sure whatever we think this guy was doing is probably all wrong. I will say that on most cargo trays the bar goes all the way under it which allows you to use adapters to make it without welding. Alot are rated for 500lbs of weight, which at the tongue is similar to say a 5000lb trailer. So the pull weight could be a bit more, not as much because of the stickout leverage but maybe a 2000lb trailer. Now doing it at both ends who the hell knows?:unsure: I will say as long as you keep air flow coming to the grille, a front hitch cargo tray could be good on a bronco especially if you use the trail sights as stabilizers for it.
swooshdave
Portland, Oregon
Mustang
Just because you have a welder doesn't make you an engineer.
HotdogThud
mk6 gti, '21 MoarDoor
:ROFLMAO:
Hopefully not the same lawyers they had on the case for the Pinto...
Bud2020
FL
Badsquatch 2.7 Lux
This mod does wonders for your approach angle. 📐
Qman68
Q
Canada
2011 Ford Mustang V6 prem, 98 Jeep Cherokee LTD
...and a camera to keep an eye on it...both front and back.
MaverickMan
Shane
Maybe this was rollover testing rig like we used to gush over last year.
TheSSBoz
23' Wildtrak
That's for carrying plastic bags full of gas... because everybody knows you need to carry those outside of the vehicle...
MaverickMan
Shane
In front, ahead of the hot engine so they stay cool and dont dissolve!
Felix808
SRV CA
