- First Name
- Joel
- Joined
- Apr 7, 2021
- Threads
- 295
- Messages
- 715
- Reaction score
- 1,298
- Location
- Arizona
- Website
- www.stage3motorsports.com
- Vehicle(s)
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Your Bronco Model
- Badlands
- Thread starter
- #1
For those of you who are just looking to adjust for tire size or gear changes, check out the Hypetech calibration module!
In stock and shipping.
Message me if interested.
Frank
2017-2021 Ford Truck Hypertech In-Line Speedometer Calibration Module 730125
Programs your Speedometer for Even the Most Massive Tires and Aggressive Gears
Many tuning devices out there on the market actually can't adjust your Super Duty's speedometer for larger tires and/or certain gear ratios. Where they fail, Hypertech succeeds with their In-Line Speedometer Calibration Module. This module plugs into the back of your Ford Truck's instrument cluster and is programmed using your home PC and Hypertech's included software. The module can adjust your truck's speedometer from half the size of your truck's factory tires to absolutely no upper limit, and can handle any gear ratio. That means no matter how big you go with your tires, Hypertech's In-Line Speedometer Calibration Module has your back. The module has a plug-and-play design and does not require permanent wiring or splicing.
Requires Instrument Cluster Removal:this module installs to the back side of your truck's Instrument Panel Cluster (IPC), which will need to be removed for installation. Please make sure to program your truck's tire size and gear ratio prior to installation.
Fitment:
Frank
Fitment:
- 2017-2021 F150
- 2017-2021 F250 & F350
- 2021 Bronco
