- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
First of the Baja Designs Bronco Light kits that are available.
2019-2021 Ford Ranger & Bronco Baja Designs Squadron Sport Complete Fog Pocket Light Kit 447607
2019-2021 Ford Ranger and Bronco Baja Designs Squadron SAE-Compliant Off-Road Amber LED Light Fog Kit 447716
Highlights:
The only thing better than getting the ability to add powerful Baja Designs wide cornering LED lights to your 2019-2021 Ford Ranger in a clean package is when you can get all the lights, harnessing, and mounts you need all in one place. Our Baja Designs Sport Complete Fog Light Package includes Baja Designs' drop-in fog light mounting brackets, two Baja Designs Squadron Sport Off-Road LED Lights, and a harness needed to tie both lights into one of your Ranger's factory plugs. This total lighting package lets you drop two powerful, yet affordable Baja Designs Squadron Sport lights into your Ranger's lower bumper "fog light" buckets so that your aggressive Ranger build gets all the lighting it needs in a simple, drop-in package. Includes Two Squadron Sports, Mounting Brackets, and Wiring
This total lighting overhaul combines Baja Designs brackets, Squadron Sport Lights, and wiring to give your Ranger impressive levels of output in a clean, OEM package. This kit comes with two Baja Designs Squadron Sport Off-Road LED Lights. Each light throws out 3150 raw lumens of light through four LEDs and with a 5000K Daylight, natural color for less driver fatigue. The Baja Designs fog light mounting brackets are made out of heavy-duty steel with a powder coat finish and drop right into your Ranger's fog light buckets without drilling, cutting, or other permanent modifications. This package also includes a plug and play harness that lets you plug both Baja Designs lighting into your factory plugs, eliminating messing with wires and giving you control with the factory hi/lo switch.
Fitment:
Highlights:
- Complete Ranger off-road LED fog pocket kit
- Includes two Squadron Sports, brackets, and harness
- Drop-in mounting brackets
- Plug and play harness for factory plugs
- 3,150 lumens utilizing 4 LEDs
- Easy, drop-in installation
Fitment:
- 2019-2021 Ford Rangers
- 2021 Ford Broncos with OEM plastic bumpers
- Will NOT fit Broncos with steel bumpers
Included Parts:- Mounting Brackets
- Plug and Play Harness
- 2x Squadron Sport Wide Cornering Lights
Specifications:- Lumens - 3,150 per light
- Wattage/Amps - 26W / 2.0A
- Dimensions - 3.5" x 2.77" x 3.5"
- Weight - 12 oz
- LED Life Expectancy - 49,930 hours
- Front Lens - Hardcoated polycarbonate
- Housing - Powder coated cast aluminum
- Bezel - Billet machined aluminum
- Hardware & Bracket Material - Stainless steel
- Built-in over-voltage protection
- IK10 & IP69K compliant
