- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
We have a few of these available in either Black/Machined or Raw/Machined. Message me if interested.
2021-2022 Bronco aFe Power Pro Series Rear Differential Cover Black with Machined Fins 46-71290B
2021-2022 Bronco aFe Power Street Series Rear Differential Cover Raw with Machined Fins 46-71290A
2021-2022 Bronco aFe Rear Diff Cover Features:
The 2021-2022 Bronco aFe Power Street Series Rear Differential Cover Raw with Machined Fins has built-in internal and external fins that transfer heat from the oil to the outside air for maximum cooling. This design ensures that your engine will be protected from overheating and be able to work harder and run longer during your off-road adventures. The cover incorporates a magnetic drain plug to capture loose particles for maximum engine protection. You will never have to worry about your engine when you are trekking the roads less traveled in your new and re-imagined 2021-2022 Ford Bronco. Have the confidence to take your vehicle wherever your travels may take you knowing your engine is protected and healthy. Increased Oil Capacity for Better, Longer-Lasting Performance
The increased oil capacity over stock of the 2021-2022 Bronco aFe Power Street Series Rear Differential Cover Raw with Machined Fins creates superior engine performance with a longer lifespan. The cover includes a calibration plug that is set to the factory oil level to prevent overfilling. It is designed to fit 2021-2022 Ford Bronco Engine Models L4 2.3L(t) EcoBoost or V6 2.7L(tt) EcoBoost, which are equipped with Dana M220 Rear axles. The durable cast aluminum protects from rocks and other debris while off-roading. This prevents the gear lube form leaking and stops contaminants from entering the differential and causing excess wear. It also keeps the differential and gear lube cool along with the built-in fins by providing improved heat disbursement and makes the vehicle weight lighter. The raw aluminum finish of this cover adds another styling element and is a beautiful finishing touch to your 2021-2022 Ford Bronco. The cover does not fit any 2021-2022 Ford Bronco Sport models.
Fitment:
Will not fit 2021-2022 Bronco Sport: these differential covers will not fit 2021-2022 Bronco Sport models
- Constructed out of Durable Cast Aluminum
- Raw Aluminum Finish
- Neodymium Magnetic Drain Plug captures loose particles for maximum protection gear protection
- Calibration Plug set to the factory oil Level to prevent overfilling
- Built-in fins transfer heat from the fluid to the outside air for maximum cooling
- Sold as a kit
- Fits Dana M220 Rear Axles
- Does not fit 2021-2022 Ford Bronco Sport
Fitment:
- 2021-2022 Bronco 4-Door
- 2021-2022 Bronco 2-Door
