2021-2022 Bronco Camburg Rear Tubular Lower Trailing Arm Kit 120031
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
So you have to cut the original bolt but you can somehow get the new bolt installed without dropping the tank? Does this mean Ford could've installed the bolt from the other direction to avoid this situation when the bushing wears out?
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Yeah, new bolt goes in from the other direction. Certainly not unique to this vehicle. My Tacoma has a few bolts that can't be removed after final assembly, but can easily be replaced from the other direction. Seems like manufacturers would factor stuff like that in, but I guess they aren't thinking about taking things apart.
Deano Bronc
Dean
Winona Lake, IN
2022 Badlands
It will be interesting to know how much more noise and vibration you are going to get with these. On my old Mustang, every rubber encased pivot point you replaced with full metal, you could hear and feel it. Maybe it won't be quite so noticeable in the Bronco.
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
the reason they mount the bolt with the nut facing away from the tank is for in a crash wont puncture fuel tank
Ford Bronco 2021-2022 Bronco Camburg Rear Tubular Lower Trailing Arm Kit 120031 science
