- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
Another in stock exhaust option for the Bronco, be sure to message me for forum pricing!
2021-2022 Bronco MBRP BLK Series Single Exit Cat-Back Exhaust Kit S5235BLK
2021-2022 Bronco MBRP BLK Series Single Exit Cat-Back Exhaust Kit Features:
MBRP designs its cat-back exhausts to produce the optimal sound for your off-road vehicle. Now they have come out with a single exit cat-back exhaust that is specifically designed for the 2021-2022 Ford Bronco. The 2021-2022 Bronco MBRP BLK Series Single Exit Cat-Back Exhaust Kit is built to perform at a high level. The design allows for the maximum exhaust flow with minimal exhaust temperatures. The exhaust exits through a single rear exit. It is not only functional, but looks stunning as well. The smooth, black-coated, aluminized steel body is stamped with the MBRP logo on the tip showing the world you invested in a high quality cat-back exhaust. The styling is unmatched and the sound is specifically tuned to fit the aesthetic of your 2021-2022 Ford Bronco. The best part of this cat-back exhaust is the easy installation. It is a simple bolt-on, no weld installation. Everything is direct fit to the OEM hangers and all the clamps and other parts are included. MBRP vows to make all of their exhaust systems with the most exacting standards in the industry. You can be ensured that you are investing in one the highest quality cat-back exhaust kits on the market.
Refined with Countless Hours of Testing
All of MBRP exhaust systems are subject to countless hours of rigorous testing to ensure that the highest performance can be achieved. The 2021-2022 Bronco MBRP BLK Series Single Exit Cat-Back Exhaust Kit has specifically been tested on the in-house Mustang 1100 AWD-SE Chassis Dynamometer. It has been driven hundreds of miles for on road and track testing with endless tweaking and modifying to get the most out the cat-back exhaust and the vehicle. The muffler design on this cat-back exhaust is a 3" fully mandrel bent tubing with a dual wall tip which offers minimal bend degree angles allowing for the fastest exhaust flow possible. The exhaust flow increase for 2.7L models is up to 35% and the increase for 2.3L models is up to 93%. Upgrading your exhaust creates increased performance for many different parts of your 2021-2022 Ford Bronco. With this cat-back exhaust, you will see increased performance from your cold air intake, programmers, modules, and downloaders. This cat-back exhaust is an investment in the overall betterment of your 2021-2022 Ford Bronco and produces beautiful sounds that would make any off-road enthusiast excited.
Fitment:
- Black-coated, aluminized steel construction
- Bolt-on installation
- 3" mandrel bent tubing
- 4" OD dual walled angle cut tip included
- Utilizes OEM hanger locations
- Up to 35% flow increase as tested on 2.7L and 93% flow increase as tested on 2.3L
- Increased horsepower and torque
- Does Not Fit Ford Bronco Sport
Fitment:
- 2021-2022 2-Door Ford Bronco
- 2021-2022 4-Door Ford Bronco
