Felix808
SRV CA
I will outsource.
It's not as hard as it seems. Besides if you intend to wheel your truck, you should be prepared make some trail repairs, especially changing an axle ;) YMMV
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Easy-peasy! IFS is so fun to work with ... :ROFLMAO:
Garemlin
Delaware
That's a whole lot of work for a 1" spacer.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
I prefer the factory rake...
I'd level it if it had squat... But this just isn't anything I'd even consider. 🤷
Factory rake on a vehicle with a soft suspension (like on the Bronco) is designed to allow for payload in the cargo bay, which will lower the rear end when loaded.
WuNgUn
Ontario Canada
2 door Squatched
It also helps give it safer, understeering handling characteristics.
MaverickMan
Shane
That’s 100% right.
Having the confidence to try is 50% of the job, the right tools is 25%. You can bumble through the rest.
You can watch all the YouTube videos you want but the only way to learn is to get your hands dirty.
Edit: With the exception of an automatic transmissions. That shit is black magic! :LOL:
Ugh I got a jeep AW4 sitting on my bench with a rebuild kit next to it. The one in my comanche usually has reverse but not uphills really. When then reverse is all but gone. I will have to invoke some kind of spell to rebuild that thing.
dgorsett
colorado
F250, Mustang, Explorer
Can’t wait to be pissed off and swearing while installing this on my back in my driveway
In 100 degree heat...getting out every tool I own one at a time...oh the joy! ;)
TurkeyRun
Central California, USA
Bronco, '02 F-350, 21 Expy, 4 Harleys and a BMW GS
Now we need someone to make a video on just flipping the studs or replacing them with bolts with out the lift.
^^ This
And if possible, doing it rolling around on their back in a driveway with minimal hand tools and a torque wrench. Because.... that's how I'll be doing it ;-)
MoabRox
Two Jeep XJs, Dodge M880, Suburban 2500
You’re a brave man. ATs are the one thing I won’t touch, other than replacing filters and solenoids. Good luck!
Lord Bronco
Lord
Jeep Wrangler
To get rid of the raked font end & level the stance of the truck.
And make it drive sub-optimally on the highway by subverting the design established by Ford engineers.
MoabRox
^^ This
And getting up a hundred times to get a different socket, etc. At least that’s how I do it!
Lord Bronco
Lord
Jeep Wrangler
John Bronco
Ram 2500/ Jeep Rubicon
HAHA. Understand that.
I don't mind doing the work to pull them. My guy is just cheap enough that I've never felt compelled to dive in.
