Zero_chance
JD
AZ
www.southvalleymustang.com
17 Mustang
The most important thing I learned here is that it is trivial to flip the lower shock bolts. Why Ford didn't just do that to start baffles me.
I would assume it had something to do with how they’re put together coming down the assembly line. Just a guess though.
GABroncin
Georgia
www.instagram.com
Jaguar E-Pace, Bronco Badlands
I wonder what the repercussions might be to flip them one at a time without the steps of removing so many parts beforehand..
Khayze427
Hayes
Valley Forge, PA
Jeep JKU
Agree. But I think we will need aftermarket bolts & nuts as the Ford OEM bolts are pressed fitted to the shock and didn’t look like the bolt head had flats. Probably for ease of robotic assembly??
Apples
Nick
2022 Jeep JLUR, 2004 Lexus GX470
Correct. Any Ace hardware. Make sure they're Grade 8.
sccohen
Socal
FJ
Interesting how it fits both non-Squatched AND Squatched. The 4WP kit is no yellow shocks🤔
Edit: Also noticed how easy it is just to remove the sway bar instead of messing with manual disco's I might just take the whole thing off when I hit the trails. ;)
Any answer on Squatched/Yellow-shock question?
BAUS67
redneck
Central PA
4WP lift is all on the top. Can't do that with "yellows".
The Zone kit is smaller lift and split between the top and the bottom. Keeps everything in check. Have not had Zone rep tell me that directly ..... yet ....... but that is my observation.
Bronco-tx
Matthew
San Antonio, TX
Toyota
Seems like they remove a lot of unnecessary parts of the front end. Is there a reason why someone can’t just remove the front strut?
Raptor911
Raptor911
Raptor911
Broadlands, VA
you have to remove all those items so the LCA can piviot down to give you room to get the shock body out.
Try it and you will see.
