- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
New Exhaust offering from Magnaflow has been added to the website for Pre-order. Expected delivery dates will be posted as I become aware of them.
Be sure to message me for Forum Pricing.
Frank
2021 Bronco 2.7L EcoBoost Magnaflow Street Axle-Back Exhaust Kit 19558
2021 Bronco Magnaflow Axle-Back Features:
The 2021 Broncos with a 2.7L EcoBoost may be some of the baddest Broncos around, but you wouldn't know it from the kitten purr that the stock exhaust puts out. The good news is that Magnaflow is here to help with their Street-Series Axle-Back Kit for 2021 Bronco 2.7L EcoBoosts give your aggressive Bronco build the mean exhaust note that it truly deserves. Each Street-Series Axle-Back kit replaces your Bronco's muffler and tailpipes with redesigned components that give your Bronco a deeper, louder, and meaner new exhaust note that is sure to turn some heads and put a smile on your face whenever you smash the throttle. The Magnaflow 2021 Bronco Axle-Back Kit features an OE-style dual-rear exit design, but comes standard with black-finished tips for an aggressive new look for your Bronco build. The 2021 Bronco Magnaflow Axle-Back drops right into place of the stock axle-back system, making it an easy way to get a new exhaust sound for your Bronco. 409 Stainless Steel Exhaust System with Dual-Exit Design and Black Tips
Magnaflow builds each of their Axle-Back Kits out of high-quality materials and carefully designs each kit for a perfect fit and function on your 2021 Bronco. Each Bronco Axle-Back Kit is made out of 409 stainless steel that provides excellent corrosion resistance in most climates and applications. Each Axle-Back Kit is built around one of Magnaflow's Street Series Mufflers that's designed from the ground up to generate a deeper, louder, and more noticeable exhaust sound all without generating excessive levels of drone and rasp at cruising speeds. The dual tailpipes exit in the factory locations in the factory rear bumper recesses, requiring no cutting or trimming on your bumper. The two tips included in this kit feature a black finish that goes along great with practically any Bronco paint color or styling theme. Each axle-back kit installs right into place of the stock axle-back system and comes with all its necessary installation hardware and instructions. Magnaflow backs each kit with a limited lifetime warranty.
Fitment: 2021 Bronco 2.7L EcoBoost
For 2.7L EcoBoost only: this axle-back kit will only fit 2021 Broncos with a 2.7L EcoBoost V6, and will not fit 2021 Broncos with a 2.3L EcoBoost nor any Bronco Sport Models.
Frank
- Gives your 2.7L EcoBoost Bronco a Mean Sound
- Louder, deeper, and more noticeable exhaust note
- Features a Magnaflow Street-Series muffler
- Dual-exit tips with a black finish
- 409 stainless steel construction
- Drop-in replacement for stock axle-back
- Backed by a limited lifetime warranty
