2021 Bronco ARB Under Vehicle Protection Panels ARB5480100
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
ARB Bronco Skid plates are now on the website and available for pre-order, as always be sure to message me for Forum pricing!
Frank.
****if you see this before our web team fixes it, red and black are not options
Ford Bronco 2021 Bronco ARB Under Vehicle Protection Panels ARB5480100 1634669604420
Ford Bronco 2021 Bronco ARB Under Vehicle Protection Panels ARB5480100 1634669633039
2021 Bronco ARB Under Vehicle Protection Panels Features:
  • 3mm press-formed, folded sheet steel adds superior strength
  • Laser cut sheet steel
  • Zinc plated and powder coated in a silver textured finish
  • Recessed mounting bolts are protected and easy to remove for vehicle servicing
  • All steel components are protected with either powder coat or zinc plating
  • Kit includes illustrated fitting instructions
  • Shipping weight of UVP is 95lb; shipping dimensions are 45 x 29 x 8in
2021 Bronco ARB Under Vehicle Protection Panels are Designed to Protect Vital Underbody Components
The 2021 Bronco ARB Under Vehicle Protection Panels protect the steering, engine sump, transmission, and transfer case. This laser cut, press formed and folded 3mm sheet steel is crafted for superior protection strength. The four meticulously designed panels each have their own protection responsibility. When they are all working together properly, you can be ensured that the underbody of your new 2021 Ford Bronco will be protected from the paved roads to the dirty, rocky trails. Do not worry about removing them for vehicle servicing. The recessed mounting bolts are easy to remove and the steel components are coated with a powder coat or zinc plating for extra protection. Be confident in getting work done on your vehicle without damaging the 2021 Bronco ARB Under Vehicle Protection Panels. Each Panel has its Owns Protection Responsibility
The 2021 Bronco ARB Under Vehicle Protection Panels has four different panels that each have a section of the underbody they are assigned to protect. Starting from the front of the vehicle, there is the Front Panel which has the most important job, to the protect engine. Going back, there is the Differential/Sump Panel which protects the front differential and mounts, the rear of engine sump, and the power steering. Continuing back to the third panel is the Transmission Panel, which protects the stabilizer bar and the transmission. Finally, there is the Transfer Case Panel located farthest towards the back and as the name would suggest protects the transfer case. All of these panels work together for full protection of the underbody of your new 2021 Ford Bronco.
Fitment:
  • 2021 2-Door Ford Bronco
  • 2021 4-Door Ford Bronco
Does Not Fit Ford Bronco Sport
FourHorses
Currently own 6 Fords
Frank.
Does it matter what front bumper you have?
Theherofails
Thomas
Phoenix
3mm? Thats only about .112". Seems a little thin for a skid plate, or am I imagining that?
Stage 3 Motorsports
Stage 3 Motorsports
Joel
wonder if they sell them separatly for us who have hd skid package already?
If past products are a tell tale then the answer will be no, as they are usually sold as a kit only and dont cary individual part#s.
As far as I am aware it does not, but will get some more information.
Sounds it but due to the construction of them with bends and reinforcement it is not a problem they are the same construction as their other skid offerings which have a great track record.
MWILD
2022 - BB Sasquatch - Mid - 2.7L
Has anyone installed these yet? I'm tempted to grab them when my BB Sasquatch gets here in early 22.
Blue's B6G
Jeremy
Los Angeles
2021 Bronco OB 2-Door V6 Sasquatch AMB High Pack
Any word on this? I was under the impression that you must have the modular bumper for proper skid plates, but this is the first that I’ve seen this ARB thread/solution. Much thanks.
  • Like
Reactions: R11
da_jokker
Jeep Wrangler JKUR
I have these bookmarked and I'm pretty sure I'm going to buy a set of these as soon as I know for sure that I'm getting a Bronco.
Stage 3 Motorsports
Stage 3 Motorsports
Joel
ARB only does not have any distinction on bumper fitment just yet and being that I havent had a set on a vehicle it is hard to say but looking at pics of the skids and pics of the bumpers I would say there a pretty high chance these will fit all bumper configs.
Jviz4u
SOCAL
Ice-Mountain special
Are those fit a plastic bumper of OBX?
kevin.gt
Kevin
Canton, GA
@Stage 3 Motorsports do you have any information on availability? trying to decide if I need to proceed with another option, or wait for these
Stage 3 Motorsports
Stage 3 Motorsports
Joel
Confirmed to be available and shipping from ARB, message me for forum pricing!
