- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
Limited stock in both toggle and up-fitter switch configuration, message me for forum pricing.
Frank
2021 Bronco Baja Designs XL Linkable Kit For Steel Bumpers - Upfitter Wiring Harness 447750UP
2021 Bronco Baja Designs XL Linkable Kit For Steel Bumpers - Toggle Switch Wiring Harness 447750
Steel XL Linkable Kit Features:
The Baja Designs Steel XL Linkable Kit is what separates hobbyists from enthusiasts when it comes to off-road capabilities. This kit comes equipped with three different pairs of Baja Designs lights: XL Sport Spot LEDS, XL Sport Driving/Combo LEDs, and the XL Sport Wide Cornering LEDs. All together, these lights will add an aggressive and bold flair to your Bronco 4-Door or Bronco 2-Door's front bumper. Your Bronco 4-Door or 2-Door must have a steel bumper to install this kit. This model comes with a standard toggle switch wiring harness. With three pairs of LEDs you'll be able to adjust your lighting specifically for maximum trail coverage, cornering and low visibility, and high speed situations. Essentially, you'll never encounter a scenario that'll leave you in the dark when your Bronco's equipped with the Baja Designs Steel XL Linkable Kit. Adventure Worthy Lights
The Baja Designs Steel XL Linkable Kit is housed in durable powder coated aluminum for maximum life expectancy. The LEDs included in this kit are estimated to have just under 50,000 hours of life on their own. The hard coated polycarbonate front lens of these lights help this kit achieve a waterproof rating of IP69K and a mechanical impact rating of IK10. This kit exceeds the military's MIL-STD-810G test which calls for testing equipment under simulated environmental conditions. After surpassing a number of specific tests designed to determine different equipment's worthiness, it's safe to say that Baja Designs didn't skimp out on the longevity of this kit.
Included:
Note: This lightbar may interfere with a portion of the viewing window in front facing camera equipped vehicles.
Frank
- Fully adjustable for full capabilities
- Includes a pre-load support bracket to maintain stiffness on rough terrain
- Built-in overvoltage protection
- Waterproof and submersible
- Replaceable lenses and optics
- Limited Lifetime Manufacturer Warranty
Included:
- x2 XL Sport Spot LED Light
- x2 Sport Driving/Combo LED Light
- x2 XL Sport Wide Cornering LED Light
- x6 XL Sport Rock Guards
- Wiring Harness
- Bronco Specific Mounts
- Measured Lumens: 18,900 Utilizing 24 LEDs
- Power (watts): 165
- Current (amps): 12
- Front Lens: Hard coated polycarbonate
- Housing: Powder coated cast aluminum
- Bezel: Billet machined aluminum
- Hardware & Brackets: Stainless steel
- Color Temperature: 5000K
- Waterproofing: IP69K
- 2021 Ford Bronco 4-Door with steel bumper
- 2021 Ford Bronco 2-Door with steel bumper
- Will not fit the Bronco Sport
